Volks AutosAH Fabrications
Results 1 to 7 of 7
    Mar 2013
    19
    boost problems on 1.8t
    some times in 2nd gear on wards the car seem to loose boost for few seconds then come back again, ive just put brand new turbo on it and this also use to happen on the old turbo that was fitted before , any ideas?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    819
    Add Vex182 on Facebook
    Boost leak? Bad map on the car?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Mar 2013
    19
    already checked pipes couldn't find any leaks , would it be good chance of being bad map then?
    Vex182's Avatar
    Apr 2012
    Hinckley
    819
    Could be, if everything mechanically is sound, then software could be a issue. Is the MAF all good?
    Mar 2013
    19
    Quote Originally Posted by Vex182 View Post
    Well I've code read the car an there's no fault codes , Il give the maf a clean tommorow and see if that helps then
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    Boost leak mate.... I had this and was confident I didn't have one. Get a smoke these if you can't find it.
    Mine was after the intercooler
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    JohnnyM100's Avatar
    Jan 2013
    Hampshire/Surrey border
    353
    Quote Originally Posted by Paradox1 View Post
    Boost leak mate....
    +1
    Though mine was a split breather hose and took me ages to find it....
  1. boost problems
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2005, 17:16
  2. MOVED: S3 Boost Problem
    By bampy in forum The Welcome Section
    Last Post: 30th May 2004, 23:04
  3. Boost Problems!!!! New Owner So Quite Worried!!!
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 12:50
  4. boost problems - following remap
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 12:59
  5. S3 Boost problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2004, 23:13
