Results 1 to 9 of 9
    Dec 2011
    609
    S3 hazard light/alarm
    The hazard warning lights on my s3 keep going off.i unlocked the car then locked it again and not even 5mins later they were flashing again its like the alarm is going but no sound,anyone any ideas how to stop this as I'm worried it could go unseen and drain my battery
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    You will need to get it scanned with VCDS.
    My ecu harness plug got water in it and shorted some pins out, one was the crash sensor pin and the hazards would keep going off.
    Dec 2011
    609
    Quote Originally Posted by Scullies View Post
    i gave it a scan with vcds and it came up drivers door sensor so cleared the code and I gave what I could see a clean with a cloth but it did it again.i took the door card off and had a poke around and touch wood its not happened since
    Feb 2006
    Lincolnshire
    691
    If the alarm siren isn't sounding, then it probably means your siren backup batteries have leaked over the circuit board, and it's triggering the false alarm.
    I think the code could well be a red herring I'm afraid.
    It's a very common problem on the 8L, and other Audi's of a similar vintage.
    All 3 of mine have suffered it, but I managed to repair all 3 too fortunately.
    Audi S3 - 2002MY - Denim Blue
    Dec 2011
    609
    I hope not as I'm having no luck with the car just now
    Mar 2013
    Chelmsford , Essex .
    198
    Quote Originally Posted by Tooks View Post
    may i ask HOW you managed to repair them please ? as my wifes one is doing the same thing !
    regards marc
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    The door switched are integrated into the door latch mechanism and are a common problem... you can replace the micro switch if yo are handy etc but generally speaking a replacement latch is required if the issue persists
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Knackered alarm sirens normally start life as 4 beeps from the rear of the car on starting the engine...
    I have done the battery replace job here (contains links to other guides)
    My minor modding thread
    <tuffty/>
    Mar 2013
    198
    <tuffty/> my friend you are a fart smeller , sorry i mean smart fella
    thanks alot
    basil
  1. Hazard lights/alarm issue..FIXED
    By Phil_H in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2011, 09:57
  2. hazard light fault
    By wesley in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2007, 17:58
  3. hazard light switch
    By downie in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2007, 19:00
  4. Hazard light problem
    By cocain in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th August 2006, 21:18
  5. Hazard light button
    By Siy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2005, 16:13
