EM TuningSky Insurance
Results 1 to 14 of 14
    Sep 2012
    West midlands
    368
    Oil pump gsf or oem??
    Ok so my car sounds like a tractor on startup untill pressure builds ie warms up,if I place my finger on rocker cover Ican feel chain hitting rocker cover when it's warm this no longer happens!!,
    So far I have replaced vvt unit with Chinese copy!!,same problem persists even fitted new rocker cover and it has teeth marks in this new one aswell I have taken rocker cover off checked cams ect all look ok,16 rollers between the two cams inlet cam is slightly towards inlet manifold were as exshaust notch is bang on?
    i have no fault codes only rattles on cold start I have taken sump off I'm going too replace oil pump, oil is golden no sludge or in pick up pipe the only thing I can think is worn oil pump I have pump off ,checking pump they say look for scores in piston??
    i have also noticed vvt piston has scores in it don't really want too take the vvt out again but I am thinking maybe ablocked oil passage in head leading too vvt unit as the old vvt had its mesh missing,I didn't check the oil passage my bad! I have checked oil pumps oil passage and it seems all clear any ideas as I'm in two minds weather too take out intake cam and remove vvt?or should I just. Try oil pump first???
    and the big question gsf/ Trojan oil pump 50? Or tps oil pump 110? Any diffrences ie do they both idle at same pressure??????
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    Jan 2011
    northants
    165
    ive fitted both pumps and never had any problems with pressures
    i would also check the gauze filter at the cam chain tensioner for sealant blockage
    Sep 2012
    West midlands
    368
    That's my worrie I'm going too have too the old vvt's gauze was missing didn't think too check oil passage could it really fit in duch a small hole I didn't find it just fitted new one I get chain hittin on cold start only once she has been started once it dosent do it again?/when warm!!
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,368
    Topran oil pump in mine. Looked to be almost OE with the part number ground off.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Same here Topran..
    Feb 2012
    68
    I have a brand new OEM oil pump still in the box and brand new oil pump pickup if you're in need.
    Sep 2012
    West midlands
    368
    Quote Originally Posted by lloydie1 View Post
    what area are you in loydie
    Sep 2012
    West midlands
    368
    [QUOTE=Prawn;1843788]Topran oil pump in mine. Looked to be almost OE with the part number ground off.[/QUOTE twice the price from tps and there usually good on prices considering they are genuine,
    whats your opinion prawn with the chain hitting rocker?? Try oil pump if no joy go for vvt or I'm thinking while oil pump is off I could blow air down the oil passage blow out any crud must say my bottom end looks very healthy pistons have no tarnish at all look brand new all my oil spray jets are in one pice and my rods look so strong lol
    May 2010
    Bedford
    2,877
    Topran is the OEM manufacturer so its all good.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Feb 2012
    68
    Quote Originally Posted by darren t View Post
    Im in Gloucester, about 15 mins from Badger5
    Sep 2012
    West midlands
    368
    well just got an oil pump took my original with me I payed 38 pounds the oil port was smaller than original!!!! So showed him he agreed so got another from out the back and low and behold it had a bigger hole same size roughly so I presume these are copy's And not an original I have bought one so fingers crossed its all good!!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Anyone know if the topran oil pump from eurocarparts/carpartsforless comes with the tensioner and chain?
    May 2010
    Bedford
    2,877
    Nope just the pump itself and obviously the chain wheel I'm pretty sure.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ill call tomorrow and check, theirs a full topran kit on ebay for less than £60 so may have to buy that.
  1. Oil Pump Failure
    By LaSarthe&Back in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2009, 10:29
  2. oil pump failure early warnings ?
    By mad max in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2006, 01:30
  3. A6 OIL PUMP...PLEASE help!!!
    By moesplace in forum Classic Audi Forum
    Last Post: 15th November 2006, 18:59
  4. oil pump fixed......turbo broken !
    By eastside_valver in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2006, 13:39
  5. Oil Pump 5 cylinder Engine
    By imported_Vinnie in forum Classic Audi Forum
    Last Post: 26th February 2005, 18:33
