Sky InsuranceBadger5
    Dec 2012
    24
    1.9tdi judder when pedal half pressed
    had the car around 6 months, its done it since ive had the car.
    when driving, if i have the accelerator pressed say quarter of the way down, the car judders.
    its not a miss fire, only way i can describe, is asif your tapping the brake pedal the same time as the accelerator is pressed.
    if you press the accelerator further down, the juddering stops.
    i suspect a fueling issue, possibly filter. any other usual things likely to be? MAF?
    its got a new flywheel & clutch so its not that
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    887
    Add Vex182 on Facebook
    Clutch switch possibly? Sounds like a problem that the 1 series can suffer from.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Dec 2012
    24
    Quote Originally Posted by Vex182 View Post
    can you elaborate? symptoms of one failing?
  1. Brake Lights wont turn on when pedal is pressed....
    By deeman88 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2012, 01:09
  2. Audi A3 tdi 140 noise on when clutch is pressed half way!! help someone
    By AntonTDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2011, 16:50
  3. A4 1.9TDi judder when accelerating hard in 4th and 5th
    By darrenwood in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th February 2009, 08:37
  4. Noise when clutch pedal lightly pressed
    By Obion in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2005, 11:39
  5. Side lights come on when brake pedal is pressed
    By Kevint in forum Other Brands & Models
    Last Post: 30th October 2005, 14:22
