Chris NottSky Insurance
Results 1 to 9 of 9
    Apr 2013
    Audi S3 2001 210 revs stop and turbo increases when accelerating (like clutch slip)
    Hi All,
    My first post in this forum, so thanks in advance to anyone spending their free time helping me out.
    So I just got a late 2001 S3 and am getting to know it. As it's a late 2001, but not quite late enough, it's the 210bhp model (released the month before they changed to 225), even tho I was sold it as a 225 - since discovered from forums that it isn't
    I'm not planning on modding it and as far as I know it's standard - I need it to last, as well as being fun, as it's done around 120k miles.
    I've had a V6 4motion golf, a 170GT TDI golf and an Alpha 1.4 multi-air 170bhp (Turbo VVT), so am used to this kind of power, (and turbos on the whole), but the S3 often seems a bit underwhelming in terms of poke.
    Anyway, I think there could be something up with it. It's most noticeable in 5/6th gear when pulling onto the motorway, and accelerating with your foot to the floor but in a high gear, so it the revs increase slowly.
    So what happens is...
    Select a higher gear so the engine isn't revving high. Boot it, and as the car slowly begins to accelerate, you hear the turbo spooling up, and the revs increase slowly as you'd expect. Then something really odd happens. It sounds a bit like the clutch is slipping (but it isn't - I think the turbo revs increase suddenly rather than the engine revs) as the power seems to drop, the rev counter stands still (or perhaps even drops) for a moment, and while the engine revs stay around the same, the turbo revs seem to increase.
    I was wondering if this is symptomatic of a boost leak that only happens at high pressure, or perhaps the diverter valve issue I've been reading about. I also wondered if there was something odd going on with the rev counter/sensor. The car can feel a bit schizophrenic - sometimes it can feel quick, and others a bit gutless.
    As I don't really know what it should feel like (as I've not had the more than a month), but something doesn't feel right.
    I hope I've given you enough info here.
    Any help very much appreciated.
    Ed
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Hi and welcome, you really need some logging done to see whats happening, where are you? there is a VCDS users list on the forum, or you may want to buy it, as it will be more than useful for sure...
    Apr 2013
    Thanks Dave - Is VCDS like VAGCOM? I'm in Cheltenham BTW.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    Quote Originally Posted by S34ED View Post
    It is the new name for it, best thing is to scan it first.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Apr 2013
    OK now I got it.
    Just found a chap on eBay in Worcester that charges a tenner. I've emailed him and will post up results here.
    Thanks s3dave & Vex182
    PS: Found one on eBay for £60ish - seems cheap??? HEX CAN USB OBD 2 VAG COM VCDS 11.3 Diagnostic Tool Kit VW Audi Seat Skoda *FULL | eBay
    Apr 2013
    Quote Originally Posted by Vex182 View Post
    Thanks both.
    Messaged bloke on eBay nr Worcester who'll do it for a tenner this weekend - will post up results.
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    Boost leak by the sound of it. Check the hoses under the inlet manifold for splits or breaks, get the system smoke tested to be sure.
    Unmapped 210 S3's are a bit underwhelming; at very best they are 145bh/ton which is likely to be less than your Alfa was. So don't try to set the goal posts based on power, go by how the car feels.
    I quite often say I'm going to do things.
    Then never do them.
    RIP S3dave
    May 2004
    nr Glos
    7,156
    If you are in Cheltenham, I am in Stonehouse, J13 M5, so if you get stuck and want smoke test, logging, dyno check etc, to confirm whats occuring, give me a call
    regards
    bill
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Apr 2013
    OK, so I went and got the VCDS thing done, as follows:
    So I rocked-up and he scanned the car:
    Saturday,13,April,2013,14:26:58:53553
    VCDS Version: Release 11.11.5 (x64)
    Data version: 20121222
    Then he reset the codes, we went for a quick blat, and then re-scanned:
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    VIN: WAUZZZ8L621000577
    Address 01: Engine Labels: None
    Part No: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 66565
    VCID: 387FEF611882BAD8D9C
    WAUZZZ8L621000577 AUZ7Z0A1869420
    No fault code found.
    Readiness: 0010 0101
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E73F9793AA684E8130
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8L0 820 043 K
    Component: A3 KLIMAAUTOMAT 0105
    Coding: 00041
    Shop #: WSC 01236
    VCID: 306FD741F0F2629891C
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 5008
    Coding: 01104
    Shop #: WSC 01236
    VCID: 458196955F70D73052A
    Address 16: Steering wheel Labels: 4B0-907-487.lbl
    Part No: 4B0 907 487 C
    Component: Lenkradelektronik D01
    Coding: 01002
    Shop #: WSC 01236
    VCID: 2C57C331DCDA0678AD4
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 R
    Component: KOMBI+WEGFAHRS. VDO D07
    Coding: 01444
    Shop #: WSC 00000
    VCID: 428B8D894E5EE008778
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    VCID: 1F4D24FD9D6CEDE0386
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 15178
    Shop #: WSC 00579
    VCID: 2F6DD43DEDCC7D60886
    1 Fault Found:
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0CFE70160921218C1C
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00014
    Shop #: WSC 01236
    VCID: E5C1F6157FB0773032A
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8L0 035 195 H
    Component: symphony II NP2 0005
    Coding: 00005
    Shop #: WSC 01236
    VCID: 3365D84D01E45980ECE
    Doesn't seem to show much really...
    Anyway today I went for a decent drive, and was overtaking a lot down A/B roads - pulling nice and loads of power.
    Then, on the way back, no turbo at all... just completely gutless. Engine runs perfectly, but there is no boost and you can't hear the turbo spinning-up.
    Could it be an N75 valve perhaps? Could this have been the issue all along?
    Anyone else had similar symptoms before their N75 went?
  1. Flywheel and turbo on Audi A3 2.0 tdi DSG
    By brettsh555 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd February 2013, 17:06
  2. Jordy's 2001 Audi S3 Quattro 210 Yellow - 300 Bhp?
    By Jordysport in forum The Project Room
    Last Post: 9th October 2011, 17:28
  3. Audi A6 2001 2.5 tdi v6 clutch and cambelt question
    By steve johnson in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th January 2011, 17:15
Tags for this Thread
