Badger5Chris Nott
Results 1 to 7 of 7
    Apr 2012
    Surrey
    23
    Fix one thing, another thing breaks..
    Hey, today I fitted a silicone crankcase breather hose as the original one had a nice hole in it. As I was changing this the top of the lower breather hose pipe just snapped off. So I have ordered that part I'm just wondering if it's simple to fit.
    I presume I can undo the plate in front of the inlet manifold to gain access? I'm no skilled mechanic so I thought I'd see if anyone can point me in the right direction to fitting this. Is there anything else on the same line I should replace before I keep coming across hoses that are just going to wither away in my hand.
    Thanks for any help!
    Becky...a3 1.8t AUM 2001
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    If its the 90deg plastic pipe I think it is then its easy to remove but a bit fiddley under the mani. The pipe is held in with a clip and then a nice tight o ring just to make your life a bit more interesting. If the plastic has broken right near the housing just make sure there are no small pieces of plastic that has or can fall into the breather housing.
    Mine broken just as I looked at it, I machined an aluminium fitting much like the billet one from integrated engineering except mine had nipple for a hose to clamp on and not an AN thread.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Take the mani off that way its easy plus you can check the condition of all pipes....
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Scullies, are you talking about the one that is on top of the oil filter housing? The one that has broke on necks car is the one that goes down off the y shaped hose from the crank case, she has ordered a nice silicone replacement but, it just looks a lot more busy ( more hoses ) around there as her is an aum and mine being AGU,
    S3dave, is it fairly straight forward to take the mani off? Would she need a new gasket when replacing the mani? I think becks has ordered some new vacuum piping for under the mani.
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Apr 2012
    Surrey
    23
    I'm trying to do this today.
    Will this be a case of having to take my inlet manifold off to gain access or is there a clever way someone knows about?
    I really need to get this done so help would be much appreciated.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    i did it with the mani on. its just fiddly, not difficult though.
    its not difficult to take the mani off, that way you can really inspect the pipes down there and prevent future issues
    phil miller's Avatar
    Sep 2012
    Devon
    843
    best advice i can give if your leaving the mani on is to smear grease on the o ring and on the housing, it will help it slide in to place easy, also if you can get the engine warm that will also help dude
    ​Wish Rachel would let me have my TDI mk5 back
  1. This is one of the things I like doing with my S3
    By S3fan in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2009, 15:03
  2. Strange engine revs issue? And another thing too....
    By JJBS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2008, 10:34
  3. Oh and another thing!!! my cars a hypochondriac
    By MeAndMyBaby in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2007, 18:54
  4. Another thing that's broke
    By LaSarthe&Back in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2007, 23:45
  5. Yet another thing - I am at the end of my patience with the S3
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2005, 17:26
