Volks AutosChris Nott
Results 1 to 8 of 8
    Feb 2013
    61
    Quick question about fitting a TIP to my 1.8t quattro....:)
    Hi, I brought this from ebay last week for a bit of a bargainHowever, I have noticed that there is 2 large inputs on the tip, one that the DV fits into and the other...well I have no idea. Ive looked at the standard item and there is a small pipe on the left that looks as though its in the same "area" but far smaller..? Have I brought the wrong TIP or am I jus not looking hard enough? Any help would be most appreciated :D cheers
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Just block it of and to the catch can mod, or get an adapter,it looks like its the port for the breather system, not sure why it is so big though..
    phil miller's Avatar
    Sep 2012
    Devon
    843
    as dave said one will be for the PUK (breather thing, fit a catch can much better) the other is for your DV
    ​Wish Rachel would let me have my TDI mk5 back
    Feb 2013
    61
    I was thinking of doing the catch can mod but probs a little later on, I assume the standard pipe that goes to the puk would easily slip in to that other hole on the tip. So I take it that small pipe in the right can just be blocked off...?
    cheers
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Nope the small pipe is for your n75 valve...
    Feb 2013
    61
    Any sort if idea wherein could get an adapter that would fit both, are we talking just a small plastic adapter from halfords etc?
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    you can still fit it ok, you have two large holes in your new TIP, one for the DV and one for the breather system. The other small hole on the TIP that is staring you in the face in the picture you have posted.... stick the n75 in there
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Feb 2013
    61
    I saw that and did consider putting it in there with the others, was just puzzled as to why the "breather" hole in the new tip was so large n what went in there
  1. Quick question about suspension fitting
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2010, 09:14
  2. Quick Question - about Bose
    By wilko in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th April 2006, 14:03
  3. A3 TDI Sport 140 - quick question about oil ...
    By Lucefer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2005, 09:20
  4. Quick Question about Aircon/Climate Control
    By DelBoyUK in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2004, 17:37
  5. Quick question about Audi a4 coilover kit
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2003, 22:13
