AH FabricationsChris Nott
Results 1 to 7 of 7
    Jun 2012
    Redhill Surrey
    629
    Add Grale1 on Facebook
    Help with fault code
    Hi guys, plugged the car in to vcds lite and it came back with vehicle speed sensor implausible signal 16685, can anyone shed any light on this for me as I have no idea what it is and not sure where to look up the code given.
    any help would be much appreciated.
    Simon
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Links are in the stickies dude...
    16685/P0301/000769 - Ross-Tech Wiki
    <tuffty/>
    Jun 2012
    Redhill Surrey
    629
    Cheers tuffty, what would I need to do now, I know that sounds stupid best to take to a vw/audi garage and get them to have a look?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    No... don't take it to a dealer... is the car driving ok at the moment? I assume there was something that prompted you to scan the car? and I am also guessing you have posted the wrong code as the code you gave is for a misfire not a speed sensor...
    If its actually the speed sensor I assume you are having speedo or other gauge issues?... have you tried clearing the code and seeing if it comes back?
    <tuffty/>
    Jun 2012
    Redhill Surrey
    629
    I plugged it into my friend vcds and she can't clear the codes for some reason, I've had no problems with the speedo apart from when I had the clutch done the garage forgot to reconnect some plug onto the gearbox as it didn't read a speed but the rev counter worked and the fuel gauge kept going up and done, but once connected it went back to normal, recently I have noticed or I think it has and that is the petrol seems to be going quickly on the gauge.
    simon
    Jun 2011
    Great Melton Norfolk
    1,340
    VCDS lite has limited capabilities.
    Jun 2012
    Redhill Surrey
    629
    Yes that's what I understood
  1. Help with Fault Codes
    By Daniel Storey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2011, 12:36
  2. Help With Fault Code 00562 - Oil Level - APY Engine
    By darreng1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th October 2010, 17:43
  3. some help with fault code??
    By mattm in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2008, 19:49
  4. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  5. Help with Fault Code
    By madkebab in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd February 2006, 13:15
