Badger5Volks Autos
Results 1 to 9 of 9
    Feb 2012
    bedfordshire
    737
    Do i need new injector seals ?
    found this the other day all the rest seem ok with only a little but if i need to change this one might as well do all is it the seals ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Its coming from somewhere dude ;P
    New seals for sure... have seen loads where they have just shrunk and gone a little hard over time (fnarr!)... the injector bungs can also contribute but its mostly the seals...
    <tuffty/>
    Feb 2012
    bedfordshire
    737
    ok mate thanks will get some seals if i remember rightly there not cheap for little rubber rings ! i might do the bungs to can this be done with the inlet mani on ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Seals are around £3 IIRC... bungs can be done with the inlet on no probs... just be careful tightening them as they are quite brittle... I used a little high temp silicon sealant on mine just because...
    <tuffty/>
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    If you get stuck, I have a bag of 20 or something o-rings.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Feb 2012
    bedfordshire
    737
    ok nice one will get on the phone and get some ordered thanks for the offer Sam but i should be ok
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Careful taking them off, the little discs on the end of the injectors can get really brittle. Mine fell apart when taking the injectors out of the manifold and I was picking loads of bits out of the head for ages and then had to source new ones, which was a nightmare.
    phil miller's Avatar
    Sep 2012
    Devon
    843
    when you tighten the plastic insert dont go to tight with them as they split, if you need any let me know, im sure ive got 2 or 3 that i took out of an old mani
    ​Wish Rachel would let me have my TDI mk5 back
    Feb 2012
    bedfordshire
    737
    Quote Originally Posted by Sam_ View Post
    all mine came out ok mate but as you said that I'm getting them fully serviced including the little discs changed to
  1. HELP... Injector seals needed... Cambs/Beds/Herts Area.
    By rusty1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2011, 18:12
  2. S4 advice needed , new member
    By redstrat in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2005, 13:12
  3. need new rotors and brake pads
    By imported_ebang in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th August 2004, 18:13
  4. Need new fog light!
    By justin_1ss in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2004, 19:50
  5. need new tyres
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2003, 08:51
