Badger5Chris Nott
Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
  1. #41
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    The lights will pivot inside, basically pull the inside of the lights up so the adjuster clip is closer to the outer casing of the light, that way you can clip it in! And cutting the wing is just trial and error. Cut little bits and refit the lights to see how they look should look like this:
  3. #42
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
  4. #43
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Mine just seem so tight to get it past the wing. I will get pics up, but there def not sitting in the wing properly, looks **** and think I need new wings unless I can't sort it a little more
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
  5. #44
    Jun 2012
    Redhill Surrey
    635
    image.jpgimage.jpgThis is what it looks like from the front
    image.jpgimage.jpgThis is the view of each wing, it seems to be catching somewhere, I've cut a fair wedge out, you can see where it's not sitting properly at the wing.
  6. #45
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    448
    You need to completely cut the metal bit off completely mate the adaptor loom is easy to make tbh and you may find you need to tap the bottom of the wing down a bit hope this helps ... If you lived closer I'd do it for ya lol
  7. #46
    Jun 2012
    Redhill Surrey
    635
    Ok cheers matey, maybe ill have a better look at weekend if its not slashing it down, I bought a adaptor cable of eBay for the loom as I didn't want to cut anything lol for the £35 they work perfect
  8. #47
    Jun 2012
    Redhill Surrey
    635
    Seeing as it wasn't raining this morning I set about seeing if could do anything with the lights, I got them to fit a lot better, had to trim a little here and there and they went back in much better and sit better also so happy now, def make the car look newer
  9. #48
    May 2012
    RETFORD, NOTTS
    1,753
    You need to just keep cutting untill they fit snug. once they do and there in tight thats it they wont go anywhere!
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Swapping pre face lift and facelift headlights?
    By @udi A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2012, 10:48
  2. Pre-Face Lift To Post Headlight Swop ?
    By Dazboss in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2010, 20:43
  3. A3 pre-face lift. A3 facelift.
    By Ravi A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2010, 10:35
  4. pre face lift headlights
    By Lenny Benford in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2007, 19:10
  5. Pre-facelift ally Mirror conversion to face-lift
    By in forum General Technical / How To
    Last Post: 29th June 2005, 22:29
