Chris NottJMB Retrofits
Results 1 to 20 of 20
    Mar 2013
    europe
    76
    Cool took car to tire fitter, for wheel bearing and cv boot . not good
    i went in thinking i wanted rear wheel bearings and inner cv boot fitted and steering wheel straightened,
    and came out needing 4 new tires and 1 steering rack, i just dont't get it lol.
    the back tire s have become square in shape and the guy said there is not enough weight on the back wheels and cheap tires, 100 a peach isn't cheap in my eyes. Its like somebody has gone over the tires with beltsander lo.
    the steering rack with the steer wheel locked so it can not move yet the wheels move at most 1cm each way, this is why when i let go of steering wheel i go to the curb
    he then said its gonna cost 1600 euro's for 2 tires and a rack if bought new, is this true, im at work in the day so cannot ring round or enquire any where about it.
    p&*^&U^&ed off to the max the ''specalist '' in stoke -on-trent who did my tracking want shooting i will post the geometry report tomoro to see if anyone can link the damage to been tracked very badly.
    thanks for any response.
    regards
    losing it.
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    sounds like he's trying to have your pants down!?
    Mar 2013
    europe
    76
    Quote Originally Posted by justarn View Post
    lol i would agree but you want see my tires they just fooked i will post pics tomorro in the day as you can see it very bad and feel it whilst driving makes you sea sick and at certain speeds and corners which is why i thought i needed wheel bearings, the steering rack when he was turning the wheels by hand left to right i saw the play in the rack it was quite a lot and clicky type noise do you know how many hours labour it is to fit a steering rack? i think i read on here the engine has to come out not too sure thou. regards
    Oct 2012
    Warrington, North West
    986
    Did you not notice your tyres before it went in?! I know everytime I get in/out my car I look at my wheels/tyres and body work for scratches, maybe not both sides depending on how I've parked etc
    Mar 2013
    europe
    76
    Quote Originally Posted by Mikemc View Post
    no i didn't notice it as it s the back passenger side is worse i thought it was wheel bearings because of the noises thats why i went in. And when i saw the tires it just confused me i've never seen it before ever
    regards
    Mar 2013
    europe
    76
    Attachment 13881Attachment 13882Attachment 13883Attachment 13884
    took photo's today.
    loads of people have had problems with these tires it seems, they are just crap
    it is called scalloped tire
    and its on maxxis tires model is on the sidewall
    Mar 2013
    europe
    76
    someone must no why this is happened????
    Oct 2012
    986
    Can't really see much tbh, on the 4th picture, it looks like a flat spot or is it the light?
    Oct 2007
    111
    some tyres just wear like that inc bridgestones!
    Oct 2007
    111
    p.s they would cause a right racket too
    Mar 2013
    europe
    76
    Quote Originally Posted by markyR View Post
    they do indeed make a racket, its getting worse by the milei'd say you can see it best on the first pic when zoomed in,
    and also the 4th picture if zoom in to the wheel in the background ,
    my quote to get me car sorted is now at just under 1000 euro's with tyres .
    I will all be fixed up by friday . then it no doubt will start all over again
    mikemc yes they are flat spots all the way round the tyres on the wear indicator in most places but not on the outside, the tyres are no longer round very mad indeed.
    i might try nokian tyres next or go back to continentals
    regards
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    Before you do anything check the depths of your front tyres. If the rears are more worn than the front this will be something to do with the quattro system. I have ran conti tyres since i've owned the car & everytime i have replaced the front tyres i get a whining noise its sounds like the haldex is ****ed. Anyway i discovered that switching the tyres round cures the noise....i almost replaced the haldex before that.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    May 2012
    RETFORD, NOTTS
    1,753
    On Quattro cars isn't it important to keep front and rear similar tread depths? Regarding uneven random flat spots, that's usually a sign of worn suspension although ive never seen anything that bad! Are the tires remoulded?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Mar 2013
    europe
    76
    Quote Originally Posted by mattyboy199 View Post
    Sound man thanks for the info, the fronts are ok 2- 3 mm above the wear blocks , but the back wheels are at certain points under the wear indicator and other points they are the same as the front,
    they were all wearing the same since new up until now
    i hope my diff isn't on the way out, i was turning the wheel off the ground earlier and they turn smoothly but seems to stop as soon as let go i didn't turn them hard as my jack wanted go for a walk ..
    also lost my locking wheel nut at xmas due to leaving it on the nut , so am unable to change them round . i think its too late to swap them round they have destroyed the audi build quality. i hope when i fit new tyres the car is silent but very much doubt it
    how much would i get if i broke the car up? , i've had enough of the constant c**p it gives me
    regards
    lost it........
    Mar 2013
    europe
    76
    Quote Originally Posted by @udi A3 View Post
    new tyre mate not remolded as far as i know, they were manufacture in summer 2012 it says on the sidewall.
    i had new springs fitted just over a year ago the shocks seem to be ok , but i'm replacing them on friday along with the tyres and a few other things
    regards.
    Feb 2006
    Lincolnshire
    719
    Try a new set of tyres first before you throw any more cash at it, or break it up!
    My old A3 TDI quattro had similar problems with odd wear on v groove tyres, sounded like the wheel bearing going and all sorts. New tyres and it was quiet again.
    Re your diff, it's mechanically connected to the driveshafts and the wheel, so I'm not surprised the wheel stopped quickly when you spun it. There is a certain amount of mechanical resistance which will stop the wheel quickly.
    Dont worry about tread differences front to rear or even side to side on a Haldex quattro, they're designed to allow for tread depth differences. Your handbook will reveal all.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Mar 2013
    europe
    76
    Quote Originally Posted by Tooks View Post
    sound mate, yea all the noises it makes sound like bearing issues, sounds like a 'sierra' with f**ked diff its that loud in the cabin, i wonder if its that loud outside
    i thought it messes the ecu head up when all tyres are diff depths?
    i have to throw cash at it , its costing a small fortune to keep running, i need hire a fuel tanker to follow me around lol, i cannot afford to fix it and fuel it up until friday . i expect a huge bill on friday so will have to live at work or something. eating bread and water for the next few months.
    regards.
    S3Zek's Avatar
    Sep 2011
    407
    Dose it sound really loud at about 40? Mine did and it was out of shape tyres on the rear (sounded like bearings) ...wouldn't hurt to put a descent make on tho.....only thing holding you to the road at the end of the day....just my 10pence.
    Mar 2013
    europe
    76
    at all speeds now mate i dont drive over 65 mph due to noise an vibration and,
    The police threatened me here in Holland they have been hounding me since xmas i think just cus i have a 13 yr old audi i get a police escort most of the time for some reason or other .
    when i jacked it up earlier and rolled the tyres round i could'nt work out what shape the tyre has become lol
    And yea you got it in one buy decent make next time
    thanks for all your replys an advise its quality.
    Mar 2013
    europe
    76
    Quote Originally Posted by losing it. View Post
    if anyones interested i got vredestein ultrac vorti r tyres fitted as audi wanted 246 euros per tyre for conti's or something else i can't remeber what they were. These i got come to just under 250 euros for 2, the car feels planted compared to what were on but i don't no how long they will last .Audi also wanted 146 euro's to fit inner cv boot and upto half a day labour to find a vacuum leak i nearly collapsed
    anyone else got these tyres fitted should i take em back .
    regards.
    also they said the steering rack can be fixed rather than replaced? would it still be cheaper fitting a refurb .thanks
  1. Part numbers request: Front wheel bearing and hub - thanks :)
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2012, 12:55
  2. What sockets for DIY 8P front wheel bearing change ?
    By marty1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th October 2011, 19:16
  3. Replies: 53
    Last Post: 14th June 2011, 09:39
  4. Replies: 9
    Last Post: 8th February 2010, 15:49
  5. went for wheel spacers and...
    By S. in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th July 2009, 10:10
