EM TuningChris Nott
Results 1 to 8 of 8
    Yohan87's Avatar
    May 2011
    404
    Optimising Stock 312mm Brake Setup
    Morning chaps,
    As above, I'm looking to remove my AP racing setup as it's overkill for what I use the car for. I still have my stock 312 setup so will be refitting that.
    It currently has Pagid discs/pads, but I was wondering if there were better disc/pad/fluid combinations out there to get the best out of it?
    Feb 2011
    Leeds
    173
    I believe that the best fluid is going to be ATE Super Blue/Orange or Motul RBF600/660. Seems to be what most of the guys going on track are using.
    The general consensus is that just a standard set of disks with a good set of pads is the best option. Most popular choices are Ferodo ds2500 or mintex m1144 for pads
    A3 TDi 196 Bhp 340 ft-lb
    The Build Thread
    Darkside Map, PD150 turbo, Allard FMIC, SFS Outlet pipe, Polybushed, Forge Short Shift , LCR Brembos, 17 TT Comps, AP Coilovers, S3 Recaros
    Feb 2013
    Sofia,Bulgaria
    11
    Another good upgrade is to switch standart calipers with ATE57 from Audi A4/A6 and replacement of the stock brake hoses with reinforced brake hoses. EBC Red/Yellow stuff is another good idea.
    Yohan87's Avatar
    May 2011
    404
    Cheers guys.
    The system has Millers racing fluid in it at the moment so I've got another couple bottles of that for doing the change over.
    HEL braided hoses are enroute also
    What is the advantage of the ATE57's?
    May 2010
    Bedford
    2,877
    Slightly bigger piston is all im pretty sure
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Yohan87's Avatar
    May 2011
    404
    Need to see what my current calipers are, from a Bora V6 4mo.
    Can't see there being that much in it?
    May 2010
    Bedford
    2,877
    Nah not really worth the hassle. Lines, fluid, plain decent discs and ds2500 all round or mintex m1155 as they`re cheaper.
    Feb 2013
    Sofia,Bulgaria
    11
    Quote Originally Posted by Yohan87 View Post
    The difference between the ATE57 and ATE54 is in the size of the piston. Digits determined size of the piston in millimeters. Although at first glance the difference is small, the increase in braking is great. I drive my S3 with the following setup:
    Front ATE 57+ EBC GD931 + EBC Red Stuff + Teflon brake hoses;
    Rear EBC GD930 + EBC Green Stuff.
    Brake fluid - Ferodo Racing DOT 5.1
    The reason I put "green" rear pads to balance the braking system using friction coefficient of pads.
  1. 312mm brake setup or carriers for a b5 1.8t qs
    By OllieQS in forum For Sale/Wanted - Audi Parts
    Last Post: 9th March 2012, 11:46
  2. 312mm Brake Setup Available
    By nashchrs in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2009, 19:50
  3. 312mm complete S3 brake setup
    By silver75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2007, 11:49
  4. Stock S4 brakes info please
    By SonTon2003 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2004, 17:59
