Chris NottVolks Autos
Results 1 to 14 of 14
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    "Soft" limp mode VS "Hard" limp mode
    Was wondering what the differences are between the above limp modes and what triggers them.
    Awhile back I was getting an over boost fault, resulting in the boost running at 5psi. It could only be cleared by erasing fault codes.
    Is that a soft or hard limp mode?
    phil miller's Avatar
    Sep 2012
    Devon
    843
    tbh there is only one limp mode, but say your lambda sensor is fooked yes you are in a sort of limp mode but apart from the light being on you prob wouldnt notice, yet the over boost you would notice
    ​Wish Rachel would let me have my TDI mk5 back
    beachbuggy's Avatar
    Surrey
    1,741
    Do you mean over boost, under boost limp mode? The Ecu has 2 pressure deviation maps that once triggered will set dtc's. there are other pressure protection maps , timing protection etc but the car needs to be pretty bad for them to trigger.
    RIP S3dave
    May 2004
    nr Glos
    7,139
    what map are you running on what hardware currently? Your original?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    I was running the remap, but I was getting very high boost spikes with the large K&N filter. I went to the guys that did the remap, but he wasn't very helpful. His answer was its impossible for the turbo to use more air than the map is asking for.
    So I have put the stock map back on now as its getting hot, hitting 35 during the day.
    My question was more of an information question, as I have seen a few posts about "soft" limp mode and thought it was different to a "hard" limp mode.
    I was wondering if different safety measures throw you into different limp modes. As I know if the actual boost vs requested boost differs by too much - you get a "hard" limp mode, that needs to be reset with VCDS.
    Been on the nef site trying to educate myself in this ecu stuff, I was enjoying the tuning steps you were sending me for my BT setup. My wife though I was crazy tho, when I was loading files and trying to explain to her how things were changing. I might have refered to it like giving birth and watching your child grow up.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    873
    Add Vex182 on Facebook
    I THINK "soft limp" is when the car dumps boost if possible, by using the n249 and this will not cause a fault code to be saved.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    RIP S3dave
    May 2004
    nr Glos
    7,139
    Quote Originally Posted by Scullies View Post
    What hardwares on your car currently?
    bill@badger5.co.uk
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    1.8 k04, 600x300 FMIC & 3" piping, 3" downpipe (custom homebrew ), Large k&n filter, forge 007p, silicone tip. stock fueling setup. Even with the stock map the boost gauge is reading 1 bar max with the k&N, when I had the stock air box and flat panel k&n filter boost was at .8 bar.
    So I assume the large filter is the cause for more air flow.
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    soft limp will reset itself but log a code. hard limp on my apy i think i got when i disconnected my injectors and cranked her over to prime the turbo i'd just changed.... never got an engine light but wouldnt boost at all until i'd reset it by disconnecting the battery.
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    Mar 2013
    Bolton
    9
    The dreaded Limp mode :/ 3 months and still havent managed to solve mine
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    do you have a chinese turbo? thats what was causing mine, had to have it off and send it to bill at badger 5. do you get boost creep if you bypass (link charge pipe straight to the actuator) the n75? i was still gaining boost once i done this= bad...
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Limp mode in an S3 is like a K03s has been fitted
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    I went into limp mode when my throttle triggered a code. It wouldn't rev or go over 5mph! Cleaned the TB and cleared codes, runs like a dream
    May 2013
    9
    Haha Sam_ agreed, I'm limping now and would still give a few cars a decent run
  1. Amk engine S3 going into limp mode if driven hard
    By Bollo in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2013, 13:04
  2. S3 Insurance quotes
    By Jodi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2004, 16:22
  3. just been quoted 495 extra for 1.8t sport...
    By xdam in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2004, 10:36
  4. Had any shock insurance quotes after a claim?
    By noodle in forum General Chat
    Last Post: 21st October 2003, 05:10
  5. It's that time of year again - insurance quotes?
    By ColinM in forum General Chat
    Last Post: 14th April 2003, 17:03
