Volks AutosChris Nott
    Mar 2013
    neath port talbot
    16
    need help on possible dv fault
    ok i got a problem on my car that its dumping its boost when under acceleration only in 4th 5th and 6th and between 3k and 5k revs it dumps from 20psi to 10 - 12 psi then after 5k it goes back up to 20 psi. i have changed maf, and n75. so i have been told it might be dump valve fault. so if there is anyone in south Wales area ish and is willing for me to try their dv valve or standard valve. just for me to try as im spending money all over the shop trying to solve this. i have pluged code reader in and no codes.
    cheers chaps
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Its the ECU dumping the boost because it thinks it has a problem... this is typically an over boost issue... what did you scan with? generic code readers are pretty limited and miss lots of VAG codes... use VCDS as if its dumping boost as you say then there will be a fault code...
    Might also help if we knew what the car was and what mods you have...
    <tuffty/>
  1. Fault Codes,need help
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2010, 23:55
  2. Temperature gauge fault need help
    By a3-se in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2009, 04:52
  3. need help fault code
    By audi-90qua in forum Classic Audi Forum
    Last Post: 28th October 2007, 12:22
  4. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  5. Please Help (Possible electrical fault) A4 :(
    By a4TDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2006, 22:08
