EM TuningMonster Motorsport
    Mar 2013
    Chelmsford , Essex .
    223
    Weird headlight !
    Hi peeps , need a bit of help after a long search , basically my mrs's 8l 2001 facelift has a dim o/s dipped headlight , upon inspection found it to have a melted + female spade connector , great I thought "bad connection giving reduced voltage and increased current resulting in said melted connector " so I cut off old connector and soldered on a new one , replaced the bulb with a new 55w H1 only to have the same sim bulb problem ! Only seem to be getting 6v at the bulb !
    So where am I losing 6 of my 12 v. ?
    Ive tried to unplug the headlight multi plug but can't ! Any ideas would be great
    Baz
    Mar 2010
    Durham NE
    578
    i would check the multi plug to headlight and the earth to the headlight and go from there.
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    Mar 2013
    223
    Quote Originally Posted by AudiS3-Turbo View Post
    yep I thought multi plug too , however I can't seem to seperate it ! How does it unplug ?
    Also going to try and run a good earth direct from the battery just to eliminate that
    Baz
    Mar 2010
    Durham NE
    578
    you will see a rectangle plastic hole at the top of the plug? put a flat bade screwdriver in the hole and pull the screwdriver back to the wire side with ease and it will unclip the latch,at the same time pull back the plug,hope that helps.
    James
    Silver Audi 8L S3
    Mar 2010
    Durham NE
    578
    Found this online.
    James
    Silver Audi 8L S3
    Mar 2013
    223
    Found this online.
    thanks James , sadly the plug in question doesn't look like that ! Will post a picture tomorrow
    baz
  1. S4 (B6) Headlight Warning is Weird - PLEASE HELP!!!
    By Lion Heart in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th June 2012, 16:37
  2. S4 (B7) Headlight Warning is Weird - PLEASE HELP!!!
    Last Post: 7th June 2012, 12:04
  3. Little bit weird question 0-100km
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2008, 15:32
  4. Weird - Oetiinger & Ebay tie up on new A3
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2003, 13:58
  5. A4 Headlights
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th June 2003, 12:23
