Results 1 to 17 of 17
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,746
    Routing cables from the cabin to engine bay
    I'm trying to fit my SPA dual gauge and the loom has fairly sizeable plugs to get through to the engine bay. Just looking for the best spot to put these through. I removed the panel under the steering wheel for a look today but couldn't see any obvious spots I could use?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    Best spot is a little rubber grommet behind the pollen filter on the passenger side. Run through there and along the back of the dash behind the radio to the drivers side. I've run in my boost gauge and WMI this way.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    S3Zek's Avatar
    Sep 2011
    407
    I think I put all my feeds to gauges up the trunking in the bay up under the panel for the windscreen wipers and down through a grommet above the glove box, I used a coat hanger draw wire to go both ways
    S3Zek's Avatar
    Sep 2011
    407
    Westy beat my lol
    S3Zek's Avatar
    Sep 2011
    407
    Ur working late Sam, about 10 at night for u isn't it?
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,746
    Cool I'll do that then cheers fellas, the loom is mega long so I should have enough space. Do you pop off the top part of the dash then? Is that easy?
    I'm not doing it tonight, I attempted it today but I got as far as taking the panel under the steering wheel off and thought, bugger this, no chance! I've been getting well lazy. I should have posted this on Friday!
    S3Zek's Avatar
    Sep 2011
    407
    Nah just the panel below the windscreen, then just use a straightened out wire coat hanger to feed it down past the glove box, u will find it will go down behind the small kick panel in the foot well.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,746
    The long centre vent in this pic? Or that whole top panel?
    S3Zek's Avatar
    Sep 2011
    407
    No below the windscreen outside the car, but your steering wheels on the wrong side so things may be diff lol one sec and I will put some picks up....
    Jun 2003
    World of my own
    9,813
    Cable routing in the 8L A3 is described with pics in this guide:
    http://freepdfhosting.com/c715a6781d.pdf
    Alex Turner
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,746
    Ah that's not my car - just a stock pic. Mine's RHD.
    Andy: Thanks for that! Awesome.
    I'll have another bash this weekend then.
    S3Zek's Avatar
    Sep 2011
    407
    Late again lol...
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,746
    Hoping I can get this plug (in the middle) through:
    S3Zek's Avatar
    Sep 2011
    407
    Go the other way then mate. Put draw wire through from top bit of fairy up liquid on the wire and grommet and pull through one at a time from inside the car in to the bay, other wise you will just have to remove the grommet and reseal with ct1 or tiger seal
    Westy's Avatar
    Dec 2008
    17,263
    I just pulled the grommet out and put a slit down it to fit over the wire at the end. I didn't bother sealing it with anything it was a tight squeeze anyway and I've not taken any water on board
    S3 Build Thread
    S3Zek's Avatar
    Sep 2011
    407
    Or yeah do as westy said and remove said grommet,
    slice,cut, stab hole!
    squeeze over plugs then push grommet back in hole with some washing up liquid with wires already in it
    at least you now have a few ideas to try for putting something in a hole lol
    Only thing left would be to put some hair round it!! Lol
  1. Best(and easiest) way to route a cable from the boot to behind the stereo
    By Rastamouse in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd June 2012, 18:11
  2. Strange noise from the cabin heater blower
    By brads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2011, 19:57
  3. How to get wires from the engine bay to the cabin? A4 B7
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th December 2008, 14:15
  4. whats involved in changing from the 150 avj engine to the 190 bfb?
    By mrjheeta in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th November 2008, 16:10
