JMB RetrofitsAH Fabrications
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By BENJAMIN
Thread: AGU temp gauge fault
    Mar 2013
    10
    Hi there all, after posting and reading through a few posts i changed the water temp sensor for a genuine VAG item as the needle was intermittent or non moving mostly.
    After replacement, on the drive the gauge went upto 90 after a few minutes but when driving yesterday it barely moves unless overtaking hard etc.
    If the car is turned off then sat idling the gauges goes up but then drops down again when the cars moving, i did also get a thermostat but havent fitted it yet, the air does get hot from the vents however pretty quick which leads me to think it aint the thermo but worth a change anyway for peace of mind.
    Any help would be greatly appreciated
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    Termostat sounds like it is duff, I agree.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    BENJAMIN's Avatar
    Mar 2011
    473
    100% your thermostat. Not a bad job to do, just a bit fiddly.
    ScottyG60 likes this.
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    Nov 2012
    portsmouth
    I did exactly the same bud. 100% the thermo. Mine was exactly the same. This is what I was confronted by when I pulled it out
    Mar 2013
    10
    Quote Originally Posted by baxterr View Post
    Jeezuz baxter! mine didnt look like that!!!!
    Thanks for the help guys, replaced it just now and its workin a treat, kinda wished i replaced with genuine vag but all good, heaters are roasting now and temp gets upto 90oC in a few mins and stays there and the gf assures me its faster as i was copilot on test due to beery lubrications. also abs light didnt come on but i doubt this is related. now to fix the hunting revs when returning to idle.........
    Nov 2012
    portsmouth
    Haha yeah, she was a little bit worn haha
    BENJAMIN's Avatar
    Mar 2011
    473
    Clean the throttle body and reset it using vcds. Bouncing revs fixed!
  1. Replies: 2
    Last Post: 20th March 2012, 22:35
  2. Temp gauge - possible faults ?
    By Stu!!! in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2011, 17:55
  3. Just got my 2001 A3 - fuel & temp gauge fault.
    By Ay3 in forum General Technical / How To
    Last Post: 12th May 2011, 13:44
  4. Audi A3 dash temp gauge fault
    By r3ahj in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2011, 23:23
  5. A3 temp gauge
    By adjturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 19:45
