EM TuningAH Fabrications
Results 1 to 7 of 7
    Nov 2011
    pboro
    185
    standard cd changer died
    As above. Was working fine till I put a new cd in today, now registers as no cd. And cant eject the cassette as sounds like there is no power or the motor has packed up. Any ideas guys?
    Nov 2011
    pboro
    185
    Just wanted to know if anyone had any ideas before I start taking it all out. Cheers guys
    JRock247's Avatar
    Jul 2012
    Hampshire
    340
    I would scan it with VCDS 1st, see if that throws up any faults. Failing that, remove the changer and check wiring between changer and head unit.
    If no sound coming from it, might have broken motor or power control circuit.
    Post back your findings.
    Nov 2011
    pboro
    185
    I havent got vcds unfortunately and dont know anyone with it near me. Was working fine until I put a new cd in it now wen u push eject nothing happens sounds like no power tbf but on the atandard unit it says no cd not sure how when theres 6 inside
    JRock247's Avatar
    Jul 2012
    Hampshire
    340
    Quote Originally Posted by S3_chris 11 View Post
    It could be a power issue or communications issue between unit and changer. Not sure if the changer has an internal fuse, maybe check that. Try removing it and reconnecting, not difficult to remove both.
    OllieGSR32's Avatar
    Feb 2013
    West London
    34
    I had exactly the same problem. I couldnt work it out I had to force the cd cassette out to get my cds and it busted the internal clips. Didnt bother me as i was changing to an after market cd HU and stealth sub enclosure. Try pressing the eject several times see if its an intermittent fault.
    JRock247's Avatar
    Jul 2012
    Hampshire
    340
    I read on another form, that if you remove the 'communication' fuses (x2) you can force the cd changer to reset itself. Try removing the side panel on the dash to reveal your fuses, locate communication fuses (use your manual) and remove the fuses and re-insert, see how that goes. You may want to jot down your radio code before you attempt removing it or the fuses.
  1. Help with the standard CD CHanger BOSE system in my S3 (57 plate)
    By Stuwhipps in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd November 2012, 17:17
  2. S3 CD Changer (the standard Audi one...) - getting picky in its old age!
    By s3mad_dude in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2012, 13:38
  3. standard audi sub, disc changer and concert head unit
    By jamesmilsome in forum For Sale/Wanted - Audi Parts
    Last Post: 1st February 2012, 22:56
  4. Adding standard changer
    By Mini-mad-matt in forum In-Car Entertainment
    Last Post: 26th September 2010, 11:11
  5. Standard HU with MP3 Changer
    By adcooper in forum In-Car Entertainment
    Last Post: 4th February 2005, 14:26
