EM TuningJMB Retrofits
    Feb 2006
    Lincolnshire
    718
    S3 Oil Leak On Startup From Oil Cooler
    Hi guys.
    Typically, and when all the car parts shops are shut today, my S3 has developed a startup oil leak that appears to be coming from the oil cooler where it meets the engine mount.
    I understand this is a common problem, and the o ring part is cheap. The problem is, where to find one today or tomorrow?!
    I have a couple of new oil filters, I have read that an oil filter seal ring is the exact same thing, and will do the job just as well as the OEM part? Certainly a few pics of the aftermarket parts look just like the oil filter ring...
    Any thoughts/experience?
    Ta!
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    The seal I think you mean is different to the oil filter one... the proper one is as you say and o-ring with two locating tabs... looks like this
    Not sure where you would find one though... halfrauds won't have anything like that so your only bet is a decent motor factors which is open on a bank holiday... again unlikely...
    <tuffty/>
    Feb 2006
    Lincolnshire
    718
    Yep, that's the one.
    I read that the tabs are unimportant, although I wonder why they're there! Probably to aid with installation or something.
    Im thinking that if the oil filter o ring is the same size, then it should work the same?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Arguably... all things considered its worth a punt....
    The tabs are to locate the o-ring so when you fit it it is in the right place to seal properly... without them it stands a chance of moving and not sealing correctly resulting in a leak... The tabs are important for this reason (to make it essentially idiot proof) but if you are aware and are careful then it could work...
    <tuffty/>
    Feb 2006
    Lincolnshire
    718
    Thanks tuffty, I think I'm going to give it a go.
    The existing one has clearly failed, so even if I get it fixed whilst I await the original part, it's better than it leaking. I'm concerned it will let go completely.
    Worse case, I can always stop and try and get a part mid week if this doesn't look like it will work, but would rather not have to take a day off sorting it.
    I will let you know how I get on!
  1. Leaking coolant Hose From Oil Filter on S4....
    By s4best4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2011, 22:24
  2. Oil leak from turbo inter cooler
    By john24susan in forum Diesel forum
    Last Post: 29th April 2009, 11:52
  3. Oil leak from rear diff
    By tobesvw in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th March 2009, 14:56
  4. oil leak from an EGR Valve and poor starting - related?
    By chill14 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2008, 20:10
  5. oil leak from turbo pipe
    By john24susan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2008, 09:57
