Chris NottSky Insurance
Results 1 to 8 of 8
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Help- S3 rear discs seized/corroded to hub and wont release, any suggestiions
    Hi Folks
    Thought this would be an easy afternoon task, replacing rear pads and discs, got everything apart ok but the discs would not come free. Have tried heat, and a large persuading stick, but no joy. Any thoughs or does any one near Plymouth have a big hub pulller that would pull the disc off? Car sat on axle stands looking forlorne.
    Thanks in advance
    Nige
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Danny-boy's Avatar
    Jan 2013
    477
    I usually go with a metal lump hammer from the back of the disc.
    The shock frees it every time.
    If that don't work, pullers would be a mega mission.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,281
    Might sound like a silly question but have you removed the little screw that secures the disc to the hub? I did a disc change on a mates merc and the screw head was covered in grime so we couldn't see it at all and thought there wasn't any. We went mental with a hammer and crowbar then found the screw after spraying about half a can of WD40 all over the disc lol. Unscrewed it and it just fell off. Won't make that mistake again!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Sep 2009
    741
    Quote Originally Posted by Westy View Post
    Hi Westy, yes the retaining screw HAS been removed, I made that mistake 20 years ago, never again. Good call though.
    Mar 2010
    Durham NE
    578
    Re: Help- S3 rear discs seized/corroded to hub and wont release, any suggestiions
    A suitable hammer will get it off, your just not trying hard enough lol
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    Sep 2005
    Derbyshire
    180
    Quote Originally Posted by AudiS3-Turbo View Post
    Agreed, as you are replacing them a good thwack will release them, failing that spray WD40 (Or CD-90) at the back of the hub tonight and smack it in the morning!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yep spray overnight and windmill in in the morning with a lump hammer
    Sep 2009
    741
    Well if at first you dont succeed, use a bigger hammer.. They eventually came off with a lot of whalloping with a lump hammer... many thanks to all for their help.
  1. Changing my rear discs and pads, a little help please?
    By Bailey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2012, 12:10
  2. help on replacing rear discs
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2008, 20:40
  3. rear discs and pads, help please.
    By S3tony in forum Handling
    Last Post: 8th February 2005, 10:48
  4. HELP!! Heated rear window and wing mirror problem
    By tboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th November 2004, 14:14
  5. Help needed - rear R32 19mm ARB for S3/TT
    By Rai in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2004, 07:20
