JMB RetrofitsEM Tuning
    Jan 2012
    21
    1.8t Brand New Clutch Fitted - Still Slipping?!
    Hey guys, my stock AUM A3 1.8t (150BHP) had a really badly slipping clutch, so we changed it for a brand new one, put everything back and it's still slipping! any ideas as to what this could be? what worries me is the clutch has always been slipping on the gearbox since we bought it, so not sure what the issue could be. Any common faults on these?
    Cheers in advance for the replies...
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    maybe oil leaking on to it if a seal has gone, what condition is the face of the fly wheel in?
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    292
    Check for a collapsed hose, could be holding the pressure although you have released pedal. Have had many time before. remove all hoses and blow through them, if partially or completely blocked, then replace. Or master cylinder sticking?
    beachbuggy's Avatar
    Surrey
    1,746
    Quote Originally Posted by wesmaster View Post
    Did you replace the flywheel, clutch plate, clutch disk and slave cylinder?
  1. New clutch needed after slipping
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2012, 21:40
  2. New clutch fitting problem
    By Nathanh393 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2011, 20:21
  3. BRAND NEW AP COILOVERS STILL IN BOX
    By RallyX in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th December 2010, 20:18
  4. brand new turbo fitted...=) 1.8t agu
    By E4 FENN in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2010, 21:15
