Volks AutosEM Tuning
Results 1 to 11 of 11
    Oct 2012
    122
    Forge TIP fitted. WOW
    Standard AGU bar a remap and pipercross panel filter. Nice healthy well serviced car.
    I fitted a s2k filter last month. Far too noisy and felt like it lost drivability at the bottom end. So reverted back to the opened up airbox and panel filter.
    I picked up a new forge TIP for peanuts, and fitted it today. Quite simple job, the main body fits perfectly between the turbo and airbox, but the DV needs a little work to fit nicely. Tided up the catch can and renewed all vacume hoses to n75, DV, FPR and wastgate while I was there.
    Went for a drive and in amazed. It has lost a little poke down below, but the way it pulls between 4-6k is night and day to before. And the noise it makes is addictive.
    Up the top end before was a little limp after the initial boost was fed in. But now it just pulls and pulls.
    Im seriously considering a 3"DP now, but really do t to loose any more low down grunt
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    i also have a AGU lump, TIP, open cone filter, 3"DP i didn't any power low down even before a remap
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Oct 2012
    122
    It's probably because its just the smoother airflow that's making it feel like it is. How did you find the 3" DP?
    My current flexi appears very loose
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    its good seems to pick up quicker. easy to fit.
    also pops and spits flames with a high flow backbox
    Mar 2013
    Whiteley & Stubbington, Fareham, UK
    50
    Where did you pick up that Forge TIP for 'peanuts' might i ask?! And can anyone point me in the direction of a 'how to' for this job please??
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    take MAF/filter off old TIP along with DV and N75. remove.
    install new TIP, DV, N75, MAF/filter
    job done, its really that easy mate.
    Oct 2012
    122
    It was £75 so half price
    http://shop.mobileweb.ebay.co.uk/sea...factoryseconds
    there is ABSOLUTELY nothing wrong with it
    Oct 2012
    122
    Well, trying to get the TIP around the water pipe is a little tedious.
    I would do it with a friend. One pushing from the top and one guiding from below.
    Do it. I was always told it makes little difference on a st1 car. I was a little dubious at first, until I took the original off. It's tiny at the bend on to the turbo.
    Mar 2013
    50
    Hiya guys,
    cheers for the bits of feedback SO i got one of those factory seconds TIPs too, absolutely nothing i can see wrong with it either so a steal at £75!
    Its an AGU TIP but my engine is AUM, however, i've read around that its no problem to fit it, despite DV and N75 being swapped position, so should be ok. The only remaining questions i have are about the other two connections to the TIP - on the stock one there is a smaller connection right up close to where it connects to the MAF and also another small connection on the back, about between the DV and N75 - just wondering if you could advise what these bits are and if the positioning of them really matters as the outlets on the Forge TIP are slightly differently located... I've got pictures but need to figure out how to load them first (if required)... Looking forward to hearing back
    Lastly, what are the kind of clips i should get for the smaller connections? I've got plenty of jubilee clips lying around that i can use for the larger ones - MAF, Turbo end, DV, N75 - just the smaller ones in question that im wondering about... Thanks guys.
    Mar 2013
    50
    Any thoughts guys?? ^^^ all good for jubilee clips now... just wondering if anyone has any wisdom as far as relocating the connection in question above to the smaller inlet near the turbo end of the AGU TIP? If not, i'll look into further detail about the bypasses that can be done to get rid of that input?
    Oct 2012
    122
    Quote Originally Posted by olibattman View Post
    Have you ordered it yet?
    if not get it bought. You'll soon figure it out with a little man bodging
  1. Fitting Forge TIP to AUM
    By audi_ro in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2013, 22:41
  2. Forge TIP fitted... And..
    By smurfworth in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2012, 23:50
  3. Fitting A Non Forge TIP...Question
    By Dazboss in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th October 2010, 13:38
  4. AGU Forge TIP fit my AMK S3??
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2010, 22:58
  5. NEW FORGE TIP FITTED, Soooo GOOD!
    By mrj0ey in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2007, 12:50
