Badger5Volks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 43
Like Tree1Likes
Thread: Turbo flutter!!! Argghh!!
    Oct 2012
    44
    Hi guys... I put a cone filter on my 1.8t agu n i could hear the turbo flutter (chatter) really loud..
    tried my mates diverter valve n same thing.. Whar could it be causing this??
    shud i buy a forge 007? Or is it somethn else thats not diverting boost back in instead of out the turbo!!?
    i dnt want to damage turbo.
    any help pls
    thanks
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    891
    My mates Octavia VRS did this when he fitted a Pipercross induction kit. He swore blind that was all he had changed, me thinking he had fitted a atmospheric DV or BOV.
    The chatter noise is usually a faulty DV, maybe running too strong as spring and not releasing pressure and as the air is hitting the blades within the compressor housing, it can cause it to stall and therefore giving the chatter sound. Not good for the turbo and should be dealt with sooner rather than later.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Check the pipe that goes from the N75 to the Actuator for splits etc
    RIP S3dave
    May 2004
    nr Glos
    7,195
    Flutter or Woosh.
    as Dave said check the pipes to the DV for leaks.. No vacuum no workie
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Oct 2012
    44
    Ok n75?!!! Will research this.. As its defo a flutter n not a whoosh.
    Il check first thing morning.
    Thanks guys.
    Oct 2012
    44
    Okk guys i checked n75 pipes.. They seemed fine. No split in pipes etc.. What else could make it flutter instead of the whoosh sound??
    I really need this sorted as i drive it everyday to work n dnt want to damage turbo as thr flutter noise is loud.
    pls help
    thanks
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    What dump valve does it have?? Standard one? The diaphrams can collapse so give it a check that its working. new one from a dealer is about 30 quid.
    RIP S3dave
    May 2004
    nr Glos
    7,195
    DV DV DV DV DV
    www.badger5.biz
    bill@badger5.co.uk
    Oct 2012
    44
    Ive already tried my mates standard dv.. Hmmnn il try another one. Thanks.. Il update once new bought tomorw.
    cheers
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,384
    Chances are your mates dv is split too mate!
    somoften the dv's on these cars are broken, and on the standard air of you usually won't hear the flutter. It only becomes apparent that you have a dv problem when you change the air filter.
    If the vac line from the inlet manifold to the dv is intact, then the dv is faulty.
    Oct 2012
    44
    Ok cheers guys.. My mate has a 007 so will try that today n get bk to u..
    thanks
    Oct 2012
    44
    Ok guys ive tried everythn!!! Tried a workn forge 007... Tried my mates n75... Checked alll pipes.. Still flutters!!
    is there anyone on here who can get to the bottom of this.. Ill come to u if ur in london.. Anything at literally any price to get this problem fixed!! Its a 1.8t agu
    thanks.
    im located in west london so anyone know any mechanic with this engine knowledge??
    Oct 2012
    44
    Can anyone help with this?? Defo not dv... Tried another n75 valve...
    Pipes are fine...
    wot else???????
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I think you will need a smoke test next mate, to rule out splits/escapes
    Oct 2012
    44
    Yh thers defo n block or leak somewer... Or maybe a faulty part? I dnt knw. Im tkn it to a vw specialist place mear by tomorw.. See if they have any idea.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    N249?
    Pipes.under then manifold.nine did this when I fitted it incorrectly. I put money on it
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Oct 2012
    44
    Quote Originally Posted by Paradox1 View Post
    N249?
    paradox is that the inlet at front of engine?? How do the pipes go on? Which way?? Sorry but im thick wen it comes to these emgines... Too many valves pipes etcc unlike my old rs turbo loll
    Oct 2012
    44
    Ok just did research n aparently there isnt a n249 on agu engines!!!
    prawn mentiones this on another thread i searched...
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,384
    There isn't one mate it won't be that
    can you get a pic up of how you've plumbed it in?
    where abouts exactly are you? If you're anywhere near me or where ill be passing I'm happy to take a look for you
    RIP S3dave
    May 2004
    nr Glos
    7,195
    if you pull the pipe off the DV when the engines running do you feel a "suck" from the pipe?
    www.badger5.biz
    bill@badger5.co.uk
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by Aaron1.8t View Post
    My bad, I forgot AGU egnines wasnt blessed with pointless crap like AUM.
    Funny this thread has come up. mines started doing the same when I boost past 3k.
    Ive changed all the vaccum pipes so im going to have a look over the weekend.
    bloody cars!
    Word!!!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    are we talking a flutter when you are letting off the throttle?
    or a 'flutter' when accelerating and boosting hard?
    two entirely different things.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I was on about letting off accelerator....
    Word!!!
    Oct 2012
    44
    Yep letting of throttle.. Ibe being doing Lot of research n someone has a injectors leakn which caused flutter.. I have 2 leaking as its wet around them so im goin to change the o rings right now n see if it does the trick.. Il let u guys know in a few hours...
    RIP S3dave
    May 2004
    nr Glos
    7,195
    lmao @ injector leaking causing wastegate flutter
    You Have'nt answered my question also
    www.badger5.biz
    bill@badger5.co.uk
    Oct 2012
    44
    Ok guys i did what badger5 said... No suck from pipe ontop of dv.. Checked the other side to that dv pipe to inlet at bottom and theres No suction there too.. But the pipe on right of inlet has vacuume so i followed that n put the dv pipe on a bleed nipple that was there.. I know its no ideal but it works n i hear the whoosh sound now.
    my question is that y is there no suction on connection under inlet?? But the pipe that connects on right of inlet does!!??
    weird one... Any help??
  28. #27
    Oct 2012
    44
    Just to make it more clear as im goin on n on loll
    theres 2 outlets under intake mani.. One goes to fuel regulator n other next to it goes to dv.. The dv one has no vacuum at all!!
    i havnt checked fuel reg one as i didnt want to break the hose clip and it looks ok..
    what could cause that outlet to not have no suction?? Could there be a blockage in the manifold for that connection??
    thanks
  29. #28
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Probably blocked, it has to see vacuum..
  30. #29
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Have you got a boost gauge?
  31. #30
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Aaron, where are you from?
    Word!!!
  32. #31
    Oct 2012
    44
    Thanks for the reply guys... I dont have a boost gauge... Im in west london. Heathrow.. What could have blocked that outlet? What would be the best way yo unblock it as i did put a hair clip into the outlet n it seemed ok.. Maybe nlocked inside inlet somewer.. Any other ways of unblocking it?? Dont want to be takn intake off as its not my area of expertiese lol
  33. #32
    RIP S3dave
    May 2004
    nr Glos
    7,195
    its blocked then..
    try poking something up the outlet little drill, piece of welding wire etc
    as I previously said.. No vacuum No workie
    you have found the source at least now
    www.badger5.biz
    bill@badger5.co.uk
  34. #33
    Oct 2012
    44
    Yh im goin to try sonethn else to poke up there long enough to try clear blockage... Im also goin to check if theres vacuum on other inlet to fuel reg...
  35. #34
    Oct 2012
    44
    Guys i tried clearing the blockage but no luck... I poked a wire into outlet but it gets stuck at a certain point.. Dnt know wots blocked it..
    can i put a t piece onto fuel reg pipe n use that vacuum to dv IF that ones not blocked too?? Lol should be ok right as ppl use that for boost gauge i think??
    thanks
    Aaron
  36. #35
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Nah dont use you fpr pipe. thats asking for trouble
    Word!!!
  37. #36
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Just take the inlet off and give it a good clean, you can clean all the ports then without fear of dumping crap into the inlet chambers..
  38. #37
    Oct 2012
    44
    Is it a easy task taking inlet off?? Would i need new gaskets etc??
    Also how would i know if theres no vacuum to fpr? As i really dont want to be taking that pipe off?
    thanks
  39. #38
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    You will need a new inlet gasket, theres abotu 10-12 allen studs to remove, and another 2 for the fuel rail that needs removing. be sure to cover the actual inlet of the engine whiel the manifold is off as the last thing you want, is anything going down there. get some carb cleaner and give it a good clean
    Aaron1.8t likes this.
    Word!!!
  40. #39
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Take the throttle body off and have a look? Probably easier than taking the while thing out.
  41. #40
    Oct 2012
    44
    Thanks paradox!!! Seems quite straight forward!! Il do that over weekend
  1. S3 Turbo Flutter - should i be worried??
    By S3-Iain in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2013, 09:44
  2. B5 Tip fitted. Turbo flutter while on boost.
    By MintyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2012, 20:22
  3. ' turbo flutter ' ?
    By jamieA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2012, 23:42
  4. turbo flutter-stutter
    By jonney in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th July 2012, 18:42
  5. Turbo 'Flutter'
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2010, 21:13
