Chris NottVolks Autos
Page 2 of 2 FirstFirst 12
Results 41 to 43 of 43
Like Tree1Likes
Thread: Turbo flutter!!! Argghh!!
  1. #41
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    Im about 15 from heathrow so if you get stuff give me a shout
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
  3. #42
    Oct 2012
    37
    Hi guys.. Did alot today to try and unclear this blocked outlet!! No luck! Took throttle body off to see if it was dirty but seemed clean inside inlet.. Tried pushing a needle.. Screw up the oultet but it just seems to stop at a certain point... Its like if the outlet is actually not open and it feels like im hitting a dead end... Does the outlet get smaller as it goes into the inlet mani?? A needle wouldnt go straight thru so wot will!!?? I havnt tested the outlet to fpr as its next to it but will do tomorw. Can i not just put a t-piece to that as i have no clue to wots blocking the outlet to dv.. It seems as if the outlet has a dead end!!!
  4. #43
    Oct 2012
    37
    Quote Originally Posted by Paradox1 View Post
    thanks paradox... Were bouts do u live as i could drive down to u?
  1. S3 Turbo Flutter - should i be worried??
    By S3-Iain in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2013, 09:44
  2. B5 Tip fitted. Turbo flutter while on boost.
    By MintyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2012, 20:22
  3. ' turbo flutter ' ?
    By jamieA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2012, 23:42
  4. turbo flutter-stutter
    By jonney in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th July 2012, 18:42
  5. Turbo 'Flutter'
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2010, 21:13
