JMB RetrofitsEM Tuning
Results 1 to 12 of 12
    Mar 2010
    Durham NE
    578
    Any auto dimming rear view mirrors? Retro fit guide fitting.
    Any 8l have the auto dimming rear view mirror fitted as standard? I've got the hole set up off a bora, including the rain sensor, wiring relays etc for 20 quid and all in black... Any one retro fitted one?
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    May 2010
    139
    It was an extra did test drive a S3 with one afew years ago, sadly it was about the only good thing about the car.
    Mar 2013
    21
    I have a auto dimming mirror on my 2005 a3 but does not work is there anything to check you could recommend to me please.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    I've got one on my 2002 S3. Great when you have a big 4x4 sitting up your chuff at the traffic lights.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Mar 2013
    Slough
    84
    Pretty sure I've got one in my 2002. Seems to have a sensor in the front of it pointing to the rear of the car. Never noticed it before this thread don't even know if it works lol
    Mar 2010
    Durham NE
    578
    Quote Originally Posted by Davjon747 View Post
    There should be a fuse for it,check fuse 5,other than that there are three wires to the unit, ignition feed,blue/black,brow for earth and the last wire is for reverse cut out feed.
    To check the operation,cover the sensor in the front of the mirror with your finger and shine a bright light into the front sensor (ignition on) and it should dim quickly
    Ive always moaned about dazzling lights behind me,so when i got offered a black mirror ,wiring replays etc for 20 quid i jumped at it...its all in and works a treat,love it!
    James
    Silver Audi 8L S3
    Mar 2010
    Durham NE
    578
    First is the button on the screen that attaches the original mirror,its a different fitting and i know if i try to remove it it will crack the glass,other option is to buy a new later screen...but not yet
    Original twist fit mirror below,auto dim on top.
    original non dim mirror button.
    The Auto dim mirror has a 20mm hole in the center for the auto wiper option,for now im wiring it in but not fitting it unless i change screens,so it will be in the glove box if need be,the auto dim button fits nicely over the original button,so i bonded it on.
    Few ours later...
    view from the rear..
    Next was the wiring,i took no shots sorry,but it soldered the blue/black wire into fuse 5 and gave it and earth,the reveres option i left off,the wiper wiring i wired into the back of the wiper relay and all done.
    The original mirror sits higher than auto dim mirror,so the tube that runs the wires through needs to be trimmed down.
    Before trimming.
    and after...
    Then just slot the mirror in place,connect the plug,fit covers and your all done.
    still need to order the lower trims so please ignore..
    So if i ever change the screen for an later auto dim mirror type all i have to do is pop the rain sensor in place,plug the wiring in and done....probably never happen lol
    enjoy
    James
    Silver Audi 8L S3
    Cobra88's Avatar
    Sep 2011
    Live in Ipswich Suffolk (orig from W London)
    435
    My 2001 tdi 110 SE has an auto dimming mirror
    works great
    no idea why it was std on mine as no other options apart from heated mirrors
    2004 Audi A4 (B6) 1.9Tdi 130 Sport (6) Avant in Dolphin Grey.
    18" S4 AVUS, RS4 Rear Roll Bar, Leather Alacantra Sport Seats, Shark Performance 170 Remap,
    BOSE, XtronsA4A double din, Full DIS, Autolocks & Alarm Chirp.
    Avant Sport 1.8T Valance with twin exit.
    Mar 2013
    21
    Quote Originally Posted by AudiS3-Turbo View Post
    where can I locate fuse 5 if I'm right I understand there are 2 fuse box, I have just also found out tonight I have auto wipers , I new I had auto lights but went to get the car washed and as soon as the water hit the winder screen my wipers started so that's auto lights and wipers working but not auto rear view mirror. Any ideas ?
    Mar 2010
    Durham NE
    578
    they share the same fuse and its the fuse board on the side of the drivers side dash,i suspect the mirror is at fault if it has all its feeds?
    edit,its fuse 8
    Garage door operating unit -E284-
    Navigation system with CD drive control unit -J401-1
    Parking aid control unit -J446-
    Garage door operation control unit -J530-
    Automatic anti-dazzle interior mirror -Y7-
    James
    Silver Audi 8L S3
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Mar 2013
    21
    No mine is totally different has a on/off button and a sensor at the bottom bellow the mirror in the middle, if that makes sense.
  1. Auto dimming rear view mirror not dimming any more??
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2012, 21:47
  2. Auto Dim Rear View Mirror
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2008, 19:04
  3. C6 4F Auto Dimming rear view mirror
    By mavala in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th December 2007, 19:56
  4. Retro-fit auto dimming rear view mirror & rain sensor
    By AlexStanley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th March 2007, 19:15
  5. auto dimming rear view mirror?
    By easytease in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th March 2006, 18:21
