Sky InsuranceEM Tuning
    Jan 2013
    20
    Strange pedals on return from garage???
    Just had cambelt re fitted as the garage got it a tooth out...anyway on return...noticed some vibration which can be heard, down in the pedal area at certain revs??? Also, im sure something is a drift as there seems to be a lite thud/click/snap which can be felt through the pedals...what is going on?? Its intermittent...could the garage have disturbed anything around this area.
    A3 1.8t 2000. Any help or ideas would as always be appreciated...could it be a cable about to snap?
    cheers
    Jan 2011
    northants
    165
    i would check the engine mount on drivers side
    i had a few left loose before and the cause a vibration/clunk
    Jan 2013
    20
    Quote Originally Posted by towcestervag View Post
    Cheers for that, will check it out in the morning.
    Jan 2013
    20
    Well, I did what I could, basically a visual check to see if anything looks loose or unbolted...it makes sense that the engine might not be in the same position...just wish I knew how to test it/check it...dont have much equipment...i read that there needs to be a 13mm gap when re setting...the garage are good but not specialists...have to do a a long distance journey on monday so I will ask the garage in the morning to check it out.
    cheers
    Mar 2010
    Durham NE
    578
    you need to change garages if thats the quality of there work,tooth out and now vibration...did u pay for this "service"?
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
  1. Strange grinding/vibrating noise from rear wheels when turning!!??
    By SamiG in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2010, 11:38
  2. Strange shaking/vibration/juddering from front wheel/s
    By Dazmo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th March 2010, 22:47
  3. Returned from the dead or suchlike :-)
    By waveform2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th November 2007, 01:04
  4. strange whirring noise coming from drivers side front wheel
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th March 2007, 23:37
  5. Strange "cluncking" noise coming from front
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 13:10
