Volks AutosSky Insurance
Results 1 to 9 of 9
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    High pitch whine under boost
    I was luckily enough to have the turbo bolts come loose, over the weekend and the gasket got blown in half. I have fitted a new gasket and tightened the bolts, I used cap bolts and drilled a hole in the heads to I could pass a piece of stainless wire thought the heads and tie them all together. Hope this stops them from coming out.
    Now when I get for a drive, there is a very high pitched whine coming from the engine bay, it only happens when the boost gets above 11psi. Its almost like a big ass supercharger noise but louder.
    At idle the engine sounds normal, even while driving at speed with low or no boost it sounds normal.
    I have checked for boost leaks by using the compressed air method, went up to 20psi and didn't find any leaks. I even checked the DV in case it wasn't closing properly and boost was creeping past and making the noise.
    could I have a cracked turbo housing or damaged bearings in the turbo.
    whats left to inspect.
    the bolt design
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    Screching noise still..
    have a read through this. mine is doing it and I have attached a video of the noise. Mines caused by a bent fin on the compressor wheel/ intake on the turbo.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    RIP S3dave
    May 2004
    nr Glos
    7,167
    as above.. if gasket blew some of it may have passed by the turbine wheel Happened to mt gt35 previously...
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    oh dear , mine sounds much like your sound clip, just louder but I guess its the camera thats making it sound softer.
    Guess its more of an excuse to get the stroker built again.
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    yes mate mine is really loud. the video was taken with my phone put on the dash board
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Do you have full power as mine was making this noise under boost but not getting full power and it turned out to be the hose from the turbo to the charge pipe was loose.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    May 2012
    RETFORD, NOTTS
    1,753
    Mine did this and was a loose inlet manifold bolt. Check all your joints are tight
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Well I went to start the car yesterday morning and the manifold/turbo joint started blowing again. So I had a look, and I could feel the gasses flowing when I put my hand near the turbo. So I backed the bolts out and tightened them again. Now there was no high pitch whine at boost. I was happy, but went for a short drive and before I got home the exhaust was blowing AGAIN!
    I remember when I took the engine out the car and stripped it down, the bolt holes in the turbo had inserts in them. Like timeserts, is that standard?
    Would it be possible for the timeserts to be working loose while the bolts are still tight?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Possibly fixed the turbo bolts backing out and the whining under boost.
    I took all 3 bolts out the turbo again and found that all 3 timeserts were loose. So I modified the bolts, I used a punch and deformed the thread in one spot about 5mm from the end. My thought was to get the bolts to lock into the timeserts and tighten then while I tighten the turbo up. Also fed s/s wire through the holes I drilled in the bolt heads. 2 days of driving now and no loose bolts or high pitch whine under boost.
    Time will tell.
  1. High pitched squeel/squuek from under rocker cover?
    By max69vk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2012, 16:43
  2. high pitch whine?????
    By shamrock in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2010, 14:58
  3. high pitch droaning noise from wheels
    By j4g3d in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2007, 19:22
  4. high mileage remap? and boost afterwards? on a 1.8T A3
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2007, 11:37
  5. High pitched noise when starting from cold
    By ajek in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th November 2004, 15:00
