Volks AutosAH Fabrications
Results 1 to 12 of 12
    May 2012
    Barry, Vale of Glamorgan, United Kingdom
    55
    best mods for a 1999 s3 8l
    Hi all.
    As title says really.i have a s3 standard apard fron n249 removal. What are your suggestions for my first performance mods.
    Bearing in mind its on 153000 miles. But its nice and strong and not using any mods. Im looking to spend around £300 ON IT THIS MONTH.
    Any ideas greatly appreciated.
    Thanks.
    Mar 2013
    Slough
    84
    Air filter and something like a 007P or silicone boost pipes would be a good start
    May 2012
    55
    Sorry forgot its got a baileys diverter too.
    Cheers for the reply.
    May 2012
    55
    Would it need mapping if I fit a tip and filter?
    Thanks.
    Oct 2011
    759
    badger 5 tip and induction kit, forget the forge, the oem diverter is perfect for you and cheap.
    Oct 2011
    759
    no map required, but it would help alot. or just get a stage one map and then the induction kit
    May 2012
    55
    Ah. Now im stuck.
    Remap first or tip and filter first.
    Cheers all
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    TIP, cone filter and heat shield first (from Badger 5) - then get a stage 1 remap after
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Oct 2011
    759
    i dont know how much a map is now days (stage one)
    bang for buck its a map.
    But after all mods have been bought you will be looking for a custom map.
    So you could just get all the mods and then a custom map.
    Mar 2013
    Slough
    84
    Do the mods mentioned then take it to Rtech for a stage 1
    BenJee_S3's Avatar
    Mar 2013
    Peterborough/Spalding
    137
    Follow BenJee_S3 On Twitter Add BenJee_S3 on Facebook Visit BenJee_S3's Youtube Channel Visit BenJee_S3's Instagram Channel
    Sorry to hijack the thread but what gains can I expect in fitting a badger tip? What is its purpose? Also what is the N249 delete?
    Best mod I've found so far is uprated brakes! Gd series discs and red stuff pads, feels miles better than before! :y:
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    872
    Add Vex182 on Facebook
    Quote Originally Posted by BenJee_S3 View Post
    The badger5 tip's allow the turbo to suck in more air, it's been shown to add up to 20bhp on a stage 1 mapped S3, it's 80mm down the whole tube, top buy before a remap.. It made mine feel much better, car revs raiser. The n249 delete gets rid of the cars ability to dump boost easily. Also makes less mess for boost leaks, makes the car respond earlier - a to do list for it is in the FAQs.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  1. Best mods for a V6??
    By dalejones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th October 2013, 08:25
  2. Best Mods for a V6??
    By dalejones in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2013, 17:19
  3. Best mods for the money what would you do ?
    By P80RSY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th May 2012, 16:09
  4. so whats the best 'first mod' for my car?
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st July 2007, 11:08
  5. Best insurer for mods
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th June 2006, 12:49
