Chris NottAH Fabrications
Results 1 to 10 of 10
    Sep 2012
    West midlands
    368
    Maf signal too high
    Can a mass air flow signal too high actually be the maf as my car stalled yesterday and threw fault code for maf signal too high usually it's over boost or lambada bank 1 but only code was maf? Could this be my issue connections checked /sprayed with contact cleaner and seem ok! Maf is genuine bosh and Farley new my actuator preload is set at 0.4 bar and holds perfect my boost gauge hits it's original position maybe a tad less but I still normally hit over boost and then lambada bank. 1 insufficient flow? Only code when car died was maf signal too high thought it was map only related but am leaning towards a new maff as well possibly?????
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Mapping... <end/>
    There is a diagnostics table that needs lifting for 'larger flow' turbo applications... get it mapped properly dude... most if not all your issues are related to mapping (or the lack of it)
    <tuffty/>
    Sep 2012
    West midlands
    368
    So I just started car it revs up and down I unplug maf and it idles perfect do mapping will definatly sort this no need for a new maf as I'd be spending my map money too buy one anyway every time I get close somthing goes I was even on m5 on my way when fuel pump failed pmsl this car is possessed
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Burn it
    <tuffty/>
    Sep 2012
    West midlands
    368
    Exactly how I fell lol
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,358
    many maps have built in 'limits' so to speak. You have found yours so they throw a code / warning if something goes a miss.
    my old AUM st1 used to throw this code after I added hardware to it after the map, the st1 map wasn't expecting to be seeing 180g/s+ and 175%+ load and threw the ''MAF signal too high code''
    Sep 2012
    West midlands
    368
    yes I agree with tuffty but I erased code started car from cold and it revs up and down violently I cut it out disconnected maff and then the car started fine must be the maf??
    Sep 2012
    West midlands
    368
    Ok so new bosh maf fitted car trouble codes erased start car fine no reving up and down car pulls strong no limp mode but still get high maf code and now traction controll light stays on dash?
    Never did this before with same fault code maf too high signal?? car fells fine now I have previously logged my car at 226.4gs !! my question is am I exceeding this now?
    thats why I get this fault is there anyway of making sure its the map being exceeded as I don't think I have a stage 1 map I think it's a stage2 lol just thought 226.4 was high enough and now I've sorted all my pipe work ect I get signal too high definatly no leaks I am chuffed too think iv maxed out my map but want too be 100 percent sure before I go spending 350 pounds on a remap??
    dont want any problems for mapping at all!!!!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    As I explained before... its a diagnostics table... even if peak airflow hasn't changed much or is excessively higher the table is graduated so any increase in airflow mid range can also potentially trip this code...
    Please also make some attempt at posting in a fashion that makes it easier to read.. I have edited the post a little to make it more readable
    <tuffty/>
    Sep 2012
    West midlands
    368
    Thank you again tuffty that's why in mid range now my boost drops back then back up for a split second like its bleeding off boost,so ill be hoping too map it very soon am I ok running it as it is tuffty for now or disconnect n75?have spotted leak on injector 3 at the rail I have left over injector o rings would these be the same for top of the injector were it meets the rail or are they diffrent too the seats on the inlet manifold?
  1. 16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    By dellboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2011, 14:59
  2. MAF signal too high. any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 21:23
  3. X-post for a friend: A3 Oil consumption too high
    By ImolaS4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 13:13
  4. New A3 Wiper Motor Replaced, Is the wiper too high
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 20:37
  5. Too high Service Costs?
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2003, 19:17
