Chris NottSky Insurance
Like Tree1Likes
  • 1 Post By Grale1
Thread: Just Bought A3 1.8t!!
    Mar 2013
    10
    Hi there, first post here and first time Audi owner but long time VAG man!
    Just got ma self and the Mrs a sweet r reg a3 turbo, pretty good car with a full years mot for 800 bucks
    Was doing the brake pads all round and rear discs when found some one had helicoiled one of the pas side caliper hanger mount bolts which i'll now have to re-helicoil
    TOP TIP!!! If your struggling for a tool to retract the rear caliper pistons i found the small angle grinder disc attachment tool is spot on for the job and saved me welding up some old knackered circlip pliers!
    Upon operating the rear window washer i found that the washer fluid is pssing out somewhere under the airbox around the strut leg?? any ideas where the hose runs as i spent some time looking for it to no avail!
    Help would be appreciated, CHEERRRss!!
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Hi and welcome to the forum,
    i had same problem with my washers there is a black case just under the filter box, if you take the air box out you can access the case easier, take the lid off and if like mine you'll see the two ends of the hard plastic hose which need to be pushed backed together . Hope this helps you out a little.
    im sure someone far mo helpful will be along shortly and explain better than me.
    simon
    ScottyG60 likes this.
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Mar 2013
    10
    Thats great cheersd man i'll look at it tonight, Also forgot to mention the airbag dash light is also on, apparently something to do with seatbelt latch tensioner on the drivers seat but i had a look and couldnt even see wires going to it???
    Jun 2012
    Redhill Surrey
    635
    My airbag light is on also, but can't help you there someone with more experience and more know how than me will help you out with that one, have you had on on vcds?
  1. Just bought 1998 A4 Avant - need a tune up?
    By BigJon in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st March 2004, 17:08
  2. Just bought an 2000 A4 1.8 and have some questions
    By cyberdude in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th December 2003, 16:57
  3. just bought a 99 audi a4 quattro
    By sllt1776 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th December 2003, 21:29
  4. Hello peeps, just bought me a S3............
    By Kipper in forum The Welcome Section
    Last Post: 15th August 2003, 13:28
  5. Just bought some Alu mirrors for 250!!
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2003, 21:51
