    jimbo_50001's Avatar
    S3X
    Jan 2007
    17
    2003 Audi S3 - When does Cambelt need changing?
    Hi
    Can anybody tell me what mileages the 2003 S3 Cambelt needs changing?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    Pretty sure it's 60k / 5 years. Make sure the water pump is done at the same time.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    If it's a 2003 then it should be due it's second replacement this year.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Mar 2009
    37
    Indeed, just had mine done @ 93000 (52 plate) only 35000 miles since last done but was 5 years ago. Not worth the risk.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Every 5 years or between 50 and 60k.
    phil miller's Avatar
    Sep 2012
    Devon
    843
    and fit the complete kit, the hyd tensioner is the ONLY thing that keeps the belt under tension, if it fails the valves have lunch in the pistons kitchen
    ​Wish Rachel would let me have my TDI mk5 back
  1. does the cambelt vibration damper need changing on bkd?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2013, 15:34
  2. A4 cab 3.0 petrol-when does the cambelt need doing?
    By reggieroo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th July 2011, 03:17
  3. When does my car actually need a Cambelt change? It's a 1.8T
    By CHRIS555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2010, 14:03
  4. gear box oil - does it need changing?
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2010, 13:02
  5. When does the cambelt need changing on a s3?
    By Tekin in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2008, 10:26
