EM TuningVolks Autos
Results 1 to 14 of 14
    Mar 2013
    Chelmsford essex
    failed MOT as rear levelling sensor missing
    Hi all, S3 8L just failed MOT as rear levelling sensor missing!! But as car lowered before I bought it, assumed it has been removed as rear axle at different angle now! How have you others coped with this problem and am I just being daft and a new one will fit back on easily no probs?! HELP
    221
    If the car is lowered Mr R then the leveling sensor won't work as it will be out of range. Presumably you can just fit one,get headlights adjusted manually and leave the self leveling disconneted. I did this on my old Bora and it passed the Irish NCT (our MOT)
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,285
    Oh my mate s3 light leveller is broke and what a ****ter to see at night! The lights literally light up 20 cm in front of the car... Without full beam it was very hard to see.
    sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    Adjust them manually. I snapped the arm on my sensor, so fixed the light at MOT pass level.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    New MOT rules suggest that self levelling system and headlamp washers (both legally required for HIDS/Xenons in the UK) should operate as intended... not sure how they test these tbh but NHN recently had this issue...
    Headlight Washer/Levelling System Check on MOT - Its Official
    <tuffty/>
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    Mine is fixed with cable ties passed the MOT 2 weeks ago no probs
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Mar 2013
    Chelmsford essex
    Exactly! Since this week all systems for levelling and washers should work from factory as intended. So gonna buy another sensor, fit it so I can re-align lights and fingers crossed. Not sure how as its lowered though........
    Mar 2013
    Chelmsford essex
    Two weeks ago was before new BS rules.....
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Be very rare that you get a jobsworth mot tester that will pull anyone up on washers and level sensors.
    I watched everything my tester did last week for the ST (main dealer too), headlight level checked, it was right, so he moved on to the brakes.
    Obv everyone wants a thorough inspection, but no one will be that thorough
    Mar 2013
    Chelmsford essex
    Well I must be unlucky coz he did go over everything but I think it might be just because the level sensor isn't there at all!!
    Lewis583's Avatar
    Mar 2010
    834
    You say "jobsworth" but if it got let through when it should have failed the Tester risks his license and possibly his livelihood.
    Also for the record, the changes only got implemented on the 20th. So prior to that, leveling etc wasn't a RfR (Reason for rejection).
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Mar 2013
    Chelmsford essex
    Has anybody else had a similar issue with lowering their car and having to disconnect this levelling sensor?
    Feb 2006
    Lincolnshire
    692
    You need to refit a rear sensor, and then adjust using VCDS.
    You can set them up on a lowered car, you just need to put the headlights into the adjustment position, adjust the lights manually, then finish the VCDS process so that the car learns the new level.
    My car is lowered, and the lights work fine.
    Audi S3 - 2002MY - Denim Blue
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,850
    Quote Originally Posted by Mr R View Post
    This sensor does not need to be disconnected/removed for lowered cars. A lot of fitters forget to disconnect it from the track arm during a suspension change, and damages it as a result.
    You've got to have a laugh!
  1. Xenon rear levelling sensor
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2012, 23:13
  2. Failed MOT, due to 2009 rear lights??
    By gazzaw888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2010, 23:26
  3. Occasional poor starter/fast idle - High CO2 levels failed MOT
    By Phlipper1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th October 2009, 12:04
  4. Failed MOT, broken rear spring
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2008, 08:59
  5. S3 failed MOT on rear spring
    By vrbob in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2008, 16:49
