Volks AutosMonster Motorsport
    Mar 2012
    96
    what fitting do i need for my oil feed (engine side) gt28 71r
    Hi as above
    what fitting have pepole used for there turbo oil feed with big turbo upgrade ?
    do i just need a bango fitting or an adaptor ?
    thanks
    john
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    AN6 Banjo..
    Mar 2012
    96
    what size is the bolt ? 12.5 mm
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    You MUST have a restrictor on your oil feed, 0.8mm. Or youl blow your seals. You can get them specifically for garretts with 6AN fitting for your feed line
    Mar 2012
    96
    i have a restrictor i need the fitting for the other end that goes on to the oil fillter housing
  1. What Mods will I need for A3 2.0 tdi 140 when remapped to 230+
    By davidrtaylor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th January 2012, 11:13
  2. What else do i need for this!?!
    By Hardsy in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2007, 12:55
  3. what materials do I need for my Swirls
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2007, 18:41
  4. What parts do I need for a service
    By johnlondonw3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th January 2007, 10:09
  5. what bulbs do i need for s3 fog lamps?
    By edward_harris in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2007, 23:27
