Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Mar 2013
    Hi I'm new and need some help
    Hi I'm new to this forum but I have a few problems with my audi a3 the car doesn't idle properly this intermittent fault only happens some time it's normally from a cold start up I get the error code p1296 the things I have done to try and fix this problem are iv changed the temp sensor this hasn't helped iv changed this twice thinking a bought a faulty one what's the next move for repairing this fault my car is an audi a3 2001 1.8 turbo petrol cheers for any help John
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Idling issues I'd suspect vacuum hoses to be split or not attached properly. The normal suspects are the ones under the manifold.
    That code is to do with the cooling system but you've changed the temp sensor, have you changed the stat?
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Mar 2013
    No iv only changed the temp sensor
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    17704/P1296/004758 - Ross-Tech Wiki
    17704/P1296/004758 - Error in Mapped Cooling System
    Possible Symptoms
    Cold start issues
    Possible Causes
    Coolant Temperature Sensor (G62) faulty
    Coolant Thermostat faulty
    Possible Solutions
    Check Coolant Temperature Sensor (G62)
    Check Coolant Thermostat
    Special Notes
    Check the stored Freeze Frame data with this fault code. Freeze Frame information will be found in the fault code description (if the module supports it) or in Generic OBD-II if the vehicle complies with those regulations.
    Freeze Frame data stored at -40 °C is generally an indication of a faulty ECT or wiring.
    Freeze Frame data stored at +140 °C is generally an indication of a faulty ECT or wiring.
    Freeze Frame data stored with in the 60-80 °C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
    Get the stat changed...
    <tuffty/>
    Nov 2012
    Kent
    451
    Add Tim_Attard on Facebook
    i bet my left nut its ur stat change it only a few quid but pita job imo and should fix this i also had idiling issues when mine went so could be related
    Mar 2013
    Thanks for all the replies I have a few other problems but one at a time ill change the thermostat next see how it goes got to change a bearing tomorrow in the snow 😓
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by John2708 View Post
    got to change a bearing tomorrow in the snow ������
    Haha Join the SWAMC....Severe weather amateur mechanics club! Head is going on tomoz in the sub zeros...
    Mar 2013
    Just recently I'm always doing something to the a3 in the cold crap weather
  1. new to forum and need some help please
    By midnight-massacre in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2011, 23:00
  2. Hello from a soon (fingers crossed) to be S3 owner and need some help
    By S3clouty in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 22:50
  3. New member needing some help
    By rolo tomassi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2009, 08:43
  4. Hi just joined up and need some help here.
    By smudger41 in forum The Welcome Section
    Last Post: 27th February 2008, 19:43
  5. Im new and need Help
    By WannabeRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2003, 19:41
