Sky InsuranceChris Nott
    Feb 2012
    20
    Head gasket done, but still! There's a leak :o
    Changed my head gasket last weekend with the typical cuts and bruises, many stops for tea and the occasional drive to halfords! (Needed the "ribe" tool to remove head bolts! 27 pound thanks audi )
    But it turns out I still have a god damn leak!! Im guessing this must be the water pump, either boiling? The water and therefor it's disappearing on me, or generally have a leak coming out of it. But I've never changed a water pump on an a3 and was wondering if anyone could give a few pointers to minimise the time it will take. It's suppose to snow soon so will have to work fast haha. I've got a replacement pump which oonly cost me 29 pound surprisingly.
    Is it a quick job or will I have to spend alot of time fiddling with the cambelt etc.
    ive got a audi a3 1.6 SE
    any help is appreciated cheers!
    Danno57's Avatar
    Apr 2011
    Taunton, Somerset
    44
    I would purchase some UV coolant leak detection dye along with a UV torch before throwing any more money at parts, then hopefully you can pinpoint the leaks location when the engines up to temperature. As for the water pump you might as well do the cambelt, tensioner etc at the same time. It's quite a big job.
    phil miller's Avatar
    Sep 2012
    Devon
    843
    did you have the head skimmed? did the old gasket have signs of where it had blown?
    ​Wish Rachel would let me have my TDI mk5 back
    Oct 2012
    56
    If you need any more of those multi-spline 'ribe' bits then this set on Amazon is cheap, has the sizes you'll need and is good quality steel. I've used my set a lot on driveshaft bolts, head bolts, door catches etc.
    http://www.amazon.co.uk/gp/aw/d/B000...sr=8-1&pi=SL75
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    The 1.6 is common to develop cracks, did you get it pressure tested and skimmed?
  1. Coils, plugs and Gasket replaced, but still a missfire?
    By A3ster in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2013, 13:28
  2. 17705 pressure drop. 1 fault, LOTS replaced but still there.
    By Craig1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th December 2011, 13:12
  3. S3 using water after head gasket been done help ???
    By a20 hvy in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2010, 18:08
  4. Aftermarket Head Unit but still use my Bose
    By brixo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2008, 23:49
  5. Anyone done Audi S3 head gasket?
    By myrichdad in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2006, 22:35
