EM TuningMonster Motorsport
Results 1 to 7 of 7
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,434
    Question Brake caliper question?
    Not sure where to post this, but I need a quick answer, and since the part is off an S3, this is the best place to ask.
    Are standard S3 front calipers the same part as my B5 Passat(TDI PD115) front brake calipers? I'm using my S3's old 312mm caliper carriers on my Passat, so I know the calipers are the same dimensions and fit, but I remember reading there are two versions of the same caliper with different piston sizes?
    And before anyone tells me to go measure them, it's cold outside, and I need to take the caliper 'off' to measure on the Passat, so no point doing the same job twice, when I can get the answer on here first to make sure.
    Cheers.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    I seem to recall the piston size being different... Kev would be able to answer this I think as I am sure this has come up in a conversation about brakes before
    <tuffty/>
    May 2010
    Bedford
    2,877
    Reg of said passat and I shall probe
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,434
    Quote Originally Posted by Jason.s View Post
    You have PM.
    May 2010
    Bedford
    2,877
    Replied but reg doesnt go in.
    S3 calipers are only compatible with Beetle RSI`s. If you`re calipers are ATE on the passat then they`ll fit the S3 carriers. If they`re Lucas (i think) then you`ll need to change the calipers in order to fit the carriers. Thats how it was on the A4`s anyway. Was only the 90bhp diesels that had the 280mm lucas brakes i think. Rest should have had the ATE`s.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,434
    I'm using the carriers off my S3, Skoda Superb V6 brake discs and the original calipers for my 312mm brake setup. After almost 200k miles, the driverside caliper is seizing, so I was wondering if my spare S3 calipers are the correct spec? I know they fit and bolt straight on!
    May 2010
    Bedford
    2,877
    I always remember Aragorn saying the A4 calipers had bigger pistons than the S3s so if the passat has the same calipers as the A4 1.8ts then that's your answer. I can see if the calipers are the same from your reg to complete that theory but I don't have the Info to see piston sizes and so on.
  1. Rear Brake Caliper Question
    By Martin82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2012, 12:35
  2. standard S3 brake caliper question
    By m8arx in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2010, 08:43
  3. quick brake caliper question.
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2007, 18:13
  4. Tool for winding brake calipers?
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2005, 15:31
  5. Another brake pad question
    By David_Moon in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2005, 22:29
