Chris NottEM Tuning
    Mar 2012
    Nottz
    104
    Advise needed.. how to fit mass air flow sensor.
    Hey pepz,
    I'm looking to atempt to fit my new mass air flow sensor unit, at the weekend. I've scoured forum to see if anyone else has done this before, on how to which I couldn't find.
    If anyone could shed some light on how it is done & what to look out for, much appricated.
    Jun 2011
    Great Melton Norfolk
    1,340
    It will take 10 mins at the most,all you will need is a philips screwdriver and a pair of grips. Take the Clip and pipe off of the MAF take out the 2 screws holding the MAF to the airbox Put in new MAF replace screws and pipe/clip job done.
    Just make sure you note direction the MAF is fitted .
    Sep 2005
    Derbyshire
    180
    You may also need a small falt bladed scredriver to remove the Electrical connector to the MAF itself. Just put it in and slowly twist.
    As has been said before, it's a very straight forward job, 2 screws in the airbox and a jubilee clip on the TIP.
    May 2010
    139
    Take the tools needed with you if your getting a exchange unit and you can do it in the car park outside audi/GSF as it takes minutes.
  1. Mass air flow sensor
    By tdisportuk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2010, 19:12
  2. Mass air flow sensor - S3 (8P)
    By warren_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2008, 09:55
  3. Mass air flow
    By rafA4 in forum General Technical / How To
    Last Post: 7th March 2005, 12:18
  4. Bora TDi 115 Mass Air Flow?
    By DunnerDan in forum Diesel forum
    Last Post: 28th February 2005, 14:10
  5. Mass Air Flow Sensor
    By darrenp in forum Diesel forum
    Last Post: 4th December 2004, 14:38
