Volks AutosSky Insurance
Results 1 to 9 of 9
    A THREE's Avatar
    Mar 2013
    Flat spot and back firing
    Hi all,i have an audi A3 2002 non turbo.i pick up a flat spot in my gears 2,3 and for.It lasts for a few seconds then the power is back.Also when slowing down/gearing down i have a back fire from the exhaust.
    does anyone have the same prob and could someone tell me what could be the cause.
    thanx guys
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Welcome!
    could be a number of things mate. have you tried getting it scanned first. that would be your best bet to find out what the problem is.
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    A THREE's Avatar
    Mar 2013
    Hi bud ,yes i have.The scan picked up a open circut on my lambda sensor which i have replaced.Could it be a fuel pump prob or do fuel pump not give intermittent probs?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I think fuel pumps could cause this and eventually the car will cut out when driving.
    I would check the fueling in the engine bay also. perhaps coils? but i dont know if there is a error code for that?
    Word!!!
    A THREE's Avatar
    Mar 2013
    Yeah i put a golf mk IV coil in(exactly the same) and still pick up that prob.Is there a way for me test my fuel pump?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    OK I get you. Its not really a test just more of an idication but when I open the door after unlocking the car, I can hear the fuel pump priming. apprently, the longer the prime the more likely it is to be a week pump.
    I cant imagine your pump would be that week though as it doesnt have a turbo sucking up all your fuel. Whats your mileage?
    Word!!!
    A THREE's Avatar
    Mar 2013
    going for 300k
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Thats impressive!
    So after fitting a new lambda sensor that fault has gone? Because your car needs the lambda for fueling.
    Deffo no more codes?
    When was timing belt done? Is the timing right?
    Check your spark plugs and plug gaps too.
    James TQ's Avatar
    Apr 2012
    Essex
    548
    300K! credit to your whip! it seems alot of people recently are having the same sort of problems, could also be spark plugs, change the fuel filter. when my back seats are down i can hear a whering kind of noise that may be the fuel pump im not sure
  1. Back from bodyshop, hand flatting hints and tips
    By 1animal1 in forum Detailing
    Last Post: 31st August 2010, 22:42
  2. idle up and down and flat spots
    By gumball b in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2010, 17:59
  3. Wobbly idle and flat spots
    By sebbelcher in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2009, 23:00
  4. Rattleing noise from left and back of car
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2004, 21:06
  5. Flat spot @5prm in 5th and 6th
    By WRN in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2003, 16:29
