AH FabricationsJMB Retrofits
Results 1 to 16 of 16
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    clutch delay valve - new simple easy mod
    i had this valve fail some time ago in the middle of town, its split, and i was stranded.
    so i replaced the valve with the straigh brass fitting pictured below:
    This is a popular mod with the BMW boys as far as im aware. i was reminded of it last night whilst reading a build thread on PH, so i took that pic today.
    it is located on the firewall , next to your abs pump. Basically, it restricts the flow of fluid when bringing the clutch up, to sort of 'dampen' the clutch, hence the name 'clutch delay valve'.
    in bypassing this you will notice a sharper response from your clutch, feels very good, alot more feel through the pedal.
    Just putting the word out there for people to try it.
    over and out
    May 2010
    Bedford
    2,877
    Ah yes i`ve read that same thread on PH and thought it sounded like a good thing.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yeah easy mod on the BMWs, never felt it much on my car
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    So anyone else done this yet? Also would the clutch need bleeding afterwards?
    .Ben.'s Avatar
    Nov 2012
    Guildford, Surrey
    114
    ^ Exactly what I was about to ask! Surely, by opening the circuit, you're introducing air? Not good in a hydraulic system, right?
    James TQ's Avatar
    Apr 2012
    Essex
    548
    thats probably the difference your feeling
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Also where did you get the braided pipe from karl?
    hughjass's Avatar
    Is there somefin in my teef?
    Dec 2012
    staffordshire
    289
    Would it work on my big boat of a car?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    I think it goes without saying you need to bleed the clutch after doing this mod...
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by .Ben. View Post
    The atmosphere isnt going to just start filling the fluid system.
    id sprung a leak, fitted that, few pumps of the clutch and it returned, a short drive will say bye bye to any air
    the part i fitted was a fluke just lying around. Il get thread sizes tho this weekend.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    <tuffty/>
    agreed.
    Mine just never needed it
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    M10x1 is normal thread size for VAG hydraulic brake/clutch fittings iirc...
    <tuffty/>
    phil miller's Avatar
    Sep 2012
    Devon
    843
    the joiner can be bought from any motorfactor, its a standard brake fitting thread and pitch
    being the clutch you should be able to pump the clutch pedal half a dozen times and it will be fine
    Karl top idea and 'another' on my to do list
    ​Wish Rachel would let me have my TDI mk5 back
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Reckon I will definately do this when I've got my engine out as its something that could potentially go wrong and can't see any downsides to removing it
    Top work Karl
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Feb 2013
    62
    ahh this may solve why my clutch is crap ie when i press down it slowly rises back up etc ive already bleed and already changed clutch master cylinder and slave cylinder in new clutch kit and dm where do i get one of these and any how to guide
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Ive wanted to post this because when the valve was removed to fix the leak, and before i knew what the hell it was, i expected the clutch to feel different and maybe feel a bit poo seeing as it was a quick fix with no bleeding. After using the car and being very inquisitive with the clutch it felt great.
    thats when i discovered it wad a common mod amongst other makes. id asked a few lads to do it just to see if i was going mad and they havent done so yet. And the thread i was reading prompted me to do this.
    As stacey said, it wont do any harm at all. Will prob take half an hour and cost a couple of quid (although i dont know where the part is from, it was in my dads tool box, very conveniently), and youl prob never have the issue of the valve bursting leaving you stranded somewere.
  1. 1999 1.8T - New to this modding lark, but keen learn. Suggestions?
    By Stunt Codpiece in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2012, 11:15
  2. New Car, Which Mods, Help Me Decide... please.
    By PhilM81 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th March 2012, 08:11
  3. New member - Audi+ Modding Newb First Ever Project
    By JNP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2011, 14:01
  4. Salesmans sympathy on delay of New A3.
    By stealth in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2004, 13:46
  5. Delay on new A3
    Last Post: 16th May 2004, 21:17
