Volks AutosAH Fabrications
Thread: Oil issue
    Mar 2013
    Staines
    Oil issue
    I've had my 2001 A3 1.8T (AUM) for a week now. I changed the oil yesterday, and put in 4.5 litres of Quantum 5w40. However, I couldn't budge the existing oil filter so I left it in place.
    After driving a few miles, the Engine Management light came on. Is it possible I've put too much oil in? Would this trigger the EML? VCDS doesn't show anything new. It still drives perfectly, just a bit concerned about this EML...
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Simple thing to do would be to check the dipstick, that would tell you if there's too much oil or not. If it's fine then reset the eml and see if it comes back.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    What do you mean VCDS doesn't show anything new? you have uncleared codes already? what codes is VCDS reporting as the CEL won't come on without a code of some description
    <tuffty/>
    phil miller's Avatar
    Sep 2012
    Devon
    843
    the engine holds 4.5 lts with a new filter, the filter holds circ 300ml of oil, i would say you have almost 1/2 lt to much in your engine, to much throw a code, could do, but as Tufty has said what codes have you got and what were there before?
    ​Wish Rachel would let me have my TDI mk5 back
  1. 2003 A4 1.8T (163) Oil Issues.
    By Rodgeri in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2013, 10:23
  2. Oil issue!!!
    By skol in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2011, 20:00
  3. Help Needed... S3 Oil issue
    By MattW86 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2011, 18:03
  4. Oil Pick up issues on a 1.8t your thoughts...
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd January 2011, 12:09
  5. Oil issue.....any suggestions?
    By tspar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2010, 05:32
