EM TuningChris Nott
Page 2 of 2 FirstFirst 12
Results 41 to 67 of 67
Like Tree4Likes
Thread: Supercharging a 1.8t (eaton m62?)
  1. #41
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    How about a compound charger set up
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  3. #42
    Jun 2009
    Leeds
    3,352
    FOR SALE
  4. #43
    STEALTHQUATTRO's Avatar
    Sep 2012
    S****horpe
    116
    how does that work andy?
  5. #44
    Jun 2009
    Leeds
    3,352
    http://www.atsdiesel.com/ats2/templa...029422272&c=36
    Some common production factory diesels engines have this set up like saab
    Saab 9-3 1.9 TTiD Review | Autocar
    FOR SALE
  6. #45
    Sep 2012
    S****horpe
    116
    this sounds a good setup! and less hard work. could you configure your own compound setup? obviously making sure its dont right.
    am prosuming the small turbo turbine must be modified otherwise it would choke the big turbo!
  7. #46
    Jun 2009
    Leeds
    3,352
    I don't have this set up
    I just run a GTX3076r turbo and happy with how it is
    FOR SALE
  8. #47
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    VWVortex.com - 01 Audi TT225 compound turbo setup
    theres a guy on vortex that was doing the compound setup, he spent a lot of cash on the project and looks like he is going single turbo after he was screwed by someone who probably couldn't complete the project.
  9. #48
    Sep 2012
    S****horpe
    116
    no way! how disheartening to get so far too! that compound setup looks the best option, move battary into the boot!. so am guessing you put a big waste gate on the small turbo to throw the boost to the big turbo! so what configuration would be best. could I still use my gt2871r A/R .86?
  10. #49
    Jun 2009
    Leeds
    3,352
    Not sure?
    FOR SALE
  11. #50
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    I also have no idea on the required setup, I think it would need a lot of researching. Don't just think 1.8, look across all vehicles. I also don't think this will eliminate the low boost problem like a supercharged&turbo setup would.
    looking at the compound setup, I wonder what would happen if you fed the exhaust into the first turbo, then the compressed air gets fed into the hot side of the 2nd turbo. Would this cause the turbine in the 2nd turbo to spool faster as its receiving pressurised airflow? Also the second turbo wouldn't be receiving "pulse" airflow.
    more twin turbo info
    AutoZine Technical School
  12. #51
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Alternatively, just go down a tried and tested route and fit a Garrett or Holset. Lag? Drop it down a gear. These sort of one off "to be different" projects just end up taking ages, costing more and end in disappointment.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  13. #52
    burns3's Avatar
    Jun 2011
    221
    you may like this blokes lotus The World's Fastest Lotus? - TUNED - YouTube seems to have had the same idea as you just in reverse.
    unreal noise
    Booooooosting just a little bit
  14. #53
    Sep 2012
    S****horpe
    116
    that lotus is awesome!
    heres some good info and dyno:
    Compound turbo dyno results - DSM Forums
    the build:
    My compound turbo set-up - Page 22 - DSM Forums
    I think its a good option its choosing the right turbo conbination want to use my gt2871r for small turbo but try get a t3 hotside small A/R
    and maybe a gt3582r big A/R for high end!
  15. #54
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,453
    Even a 2871 doesnt spool fast enough to make it worth while. What do you get? Full boost by 4k???
    Compounding with your 2871 will be no different, and a stroker gtx3071 will spool the same and make tonnes more power.
    To make it worthwhile you need something small and punchy that will compensate for the big one. You really need 2 turbos at opposite ends of the lag spectrum.
    It cant be too small obv. Compounding will always hinder the bigger turbos performance.
    So you need a big turbo that will see your power goals quite easily. And another that WILL fill in the lag area. Your 2871 wouldnt.
  16. #55
    Jun 2009
    Leeds
    3,352
    We should all be asking what the car will be used for anyway?
    The GTX3071 is a great turbo that will get you into the 500 bhp mark
    If it was me and i had the cash i would sell the 20v engine and fit a TTRS engine or a R32 and turbo that.
    Both will give great torque and get more than enough power that anyone can wish for depending on how deep your pockets are.
    Both engine with the right money will give between 400 to 1000+ bhp
    FOR SALE
  17. #56
    Jun 2009
    Leeds
    3,352
    Another set done years ago that i saw
    FOR SALE
  18. #57
    burns3's Avatar
    Jun 2011
    221
    Loving the wooden bonnet lifter lol
    What was that engine in andrew a mk2 rs2000?
  19. #58
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,453
    Looks like it from the headlight.
    I like the idea of compund charging. But the smaller turbo MUST restrict the larger to some extent.
  20. #59
    burns3's Avatar
    Jun 2011
    221
    Thats what i was thinking Karl.
    I still think its alot of work for the gains but would be impressive on the road/track if it worked properly.
    Even the delta s4 wasn't meant to be brilliant at low down revs with the supercharger, suppose that how it killed henri toivonen one of the greatest drivers ever because he was having to drive it flat out everywhere to make it work.
  21. #60
    Sep 2012
    S****horpe
    116
    yea I thought the gt2871 would be to small for top and too big for spool!
    so the better option woild be a gt2582! and gt3582! its in an 8L a3.
    surly the t25 flange would restrict the big turbo?
  22. #61
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,453
    Quote Originally Posted by STEALTHQUATTRO View Post
    yeh or 2860 for small.
    T3 flange both for flow and better heat management. 44mm wastegates.
    T25 would prob be too small on the smaller turbo. Hindering the gt35
    lol heres me speculating on what would work. I know sod all about compound charging. Just trying to think about it logically.
  23. #62
    Sep 2012
    S****horpe
    116
    hay it carnt be that hard surly!! i love a challenge!
    just thinking ant the gt2871 and gtrs the same but the compressor?
    if so I could change the compressor!
    also the external wastegate would plumb back in before the big turbo so the extra boost would spool it.
    its just making sure the wastegate flows enough and not too little to stall big turbo
    am just trying to be logical but I think I need some figures doing!!
  24. #63
    Aug 2011
    160
    I'm in the middle of doing a merc m62 20v golf and their is loads of room, the only merc m62 has a clutch pulley which would make life a little bit easier as at a set rpm or boost level you could turn it off, but due to it's large pulley size (110mm) and VW's 140mm crank pulley you wouldn't see much boost. If your target is 600ish then an r32 can handle that easy, I've helped a mate make one with 640hp will post up the plot tomo, thinking back it made over 400 torque @3kish and that uses the biggest T3/T4 no gt bearing turbo.
    Going back you maybe better keeping the std ecu and then use another one to control the bypass valve.
    Audi A3 1.8T AUM Sport with more doors.
  25. #64
    Sep 2012
    S****horpe
    116
    I dint even know you could link the ecu!
    do you know the max boost of the m62?
    I do think the compound setup should produce good results but
    but its the room!!
    I dont ethen know what these 1.8t blocks can take!?
    watch the second clip on this thred:
    Compound Turbocharging
    as long as u got a good flowing mani the wastegate will throw the rest of the overboost to the big turbo!
  26. #65
    Aug 2011
    160
    M62 eatons at a push can flow air to see 270-290 but with very high air temps, Eaton are also know as 'heatons' lol
    Well if you geared the Eaton 2:1 70mm pulley to your OEM 140mm you'll see 6psi just off idle and 8-10 by 2k. The 2nd ecu would just need an rpm signal and boost to switch the valve so that the air would bypass the Eaton once the turbo has come online at which ever rpm/boost point.
    Some have seen 550/650 HP from 20v motors some have lasted and some haven't, way I look at it is which is safer 600 by 4 pot =150 a cylinder or 600 by 6 pot=100 each cylinder.
  27. #66
    Sep 2012
    S****horpe
    116
  28. #67
    Sep 2012
    S****horpe
    116
    am going to open a new thred on compound setups! as am not going eaton. !!
  1. Fitting the Eaton M62 PES G2 supercharger
    By Foxmeister in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th March 2011, 10:40
  2. Supercharging the S8 V8
    By naraidoo in forum A8/S8 forum
    Last Post: 22nd November 2003, 14:43
  3. Is There a Turbo or Supercharger for a 98 A6 2.8
    By mikepg in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th November 2003, 02:21
  4. PES G1 Supercharger on ebay!!
    By audrenalin in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd November 2003, 22:24
  5. Supercharged 2.8 or K04 1.8 ????
    By dominicnyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st July 2003, 04:45
