Chris NottSky Insurance
    Feb 2013
    Kidderminster
    14
    Front suspension problem?!
    Morning all, I've mentioned on a previous post that I had a snapped spring on my s3. But after taking a closer look yesterday I don't think it is. As I'm new to cars please stick with me on this....... Under the bonnet where the shock bolts in, there is three little nuts with a bigger one in the centre covered by a black plastic cap!. Right, when I go from full lock to full lock the passenger one hardly moves. But the drivers side one moves about 30mm. As I'm going from lock to lock there is a clunk type noise. A lad at work says there is a bearing under the black caps and its that that has gone, not the spring.
    Any insight from yours selves would be appreciated. Cheers webby
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,617
    Heres some info
    Westle's Suspension Thread
    mark_S3's Avatar
    Yorkshire & Humber Events Mod
    Sep 2012
    Wakefield
    494
    I had a similar knocking noise coming from the NSF, and just replaced the top strut mounts.
    Steering is a whole lot better and the knocking noise has gone.
    But the knocking noise could be either the above or Anti Roll Bar Bushes, Track Rod Ends, Lower Ball Joints, worn bushes in the arms or a knackered strut.
    I would check all the above for play and condition.
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SRP Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, Jetex Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes *
    ~ Soon to be fitted: s3dave Adjustable Control Arms ~
    http://www.audi-sport.net/vb/signatu...pic65622_5.gif
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    the clunk could be the broken spring moving when you lock to lock the steering.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    You need to take the wheel off and check the spring, if the springs fine then its the top mount, youll need to change both side and also do the bearings as well.
    Feb 2013
    Kidderminster
    14
    Cheers for the replies. Before I have the koni shocks and springs fitted ill get it checked over and replace what ever is bust at same time.
    Thanks again.
  1. squeky front suspension
    By misledyouth in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2008, 12:26
  2. suspension problems
    By shariain in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2004, 17:58
  3. S3 Front Suspension Knock
    By gdwood in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2004, 12:25
  4. Front Suspension Woes (a wee bit longish)
    By IanWood in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th May 2004, 14:04
  5. A/S3 front suspensions??
    By Drill in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2003, 14:33
