Badger5EM Tuning
Results 1 to 7 of 7
    Oct 2012
    42
    Ignition module?
    Hi guys,
    had my 1.8t agu for a few months now...
    Today i put a cone filter on it.. But theres a ignition module i believe its called on the airbox.
    I left it tied to a pipe with both connectors connected.. What is it?? Car wont start when unplugged. What have u lot done with it?
    Also car flutters now so looks like a faulty diverter valve??
    any help pls
    thanks
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    You're not talking about the MAF are you? Can you take a picture of it?
    If it is the MAF, you're going to want to put that back.
    Check the small vacuum hose on top of the dv is connected properly and isn't split.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    AGU's have an ignition amp.. this is normally fitted to the airbox.... as long as its secure then it should be fine... you can cable tie it to something (alloy bit facing out as it gets warm) or make a bracket to attach it too
    <tuffty/>
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,787
    +1 as per tufftys post
    The metal bit acts like a heat sink
    <Jay A3 build thread>
    241bhp K03s - R Tech
    Oct 2012
    42
    Ahh cheers tuftty!! Thats wot i did. Also flutter?? New diverter valve?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Assuming its plumbed in right... is it an OEM one or aftermarket one?
    <tuffty/>
    Oct 2012
    42
    Its a OEM one... Looks very old n dirty so might need changn.. Ill change it n see.
    thanks for the reply guys.
  1. ignition module and air solenoid thingy
    By audiv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2011, 20:34
  2. WANTED!! Ignition Module
    By sherry in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th April 2008, 12:57
  3. Wanted! Ignition module
    By sherry in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2008, 21:26
  4. 1 cylinder failed. Ignition module needed... 800 !?!?
    By imported_AudiOwner96 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th August 2005, 20:07
  5. HELP! ignition control module!
    By imported_tristram in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2004, 21:55
