Volks AutosEM Tuning
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Wheel bearing issue
    Hi guys, took the car a trip to Suffolk over weekend and since I've owned it there has been a rumbling noise from the wheels at front, coming home Sunday the car felt weird so today I jacked the car up and the passenger side front has a lot of play when you hold the wheel at quarter to three. Is it pos to change them yourself with a hub puller? Or just a lot easier to get a garage to do the job? And would you have the track rod ends changed also as they are cheap ones, and the inner track arms look like they have been on since the car was new, worth replacing also??
    thanks simon
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Front bearing requires a press... if you are competent then you can remove the upright and take it to a garage to press the old bearing out and press the new bearing in... it would require a puller to remove the part of the bearing that gets left on the hub too... then pressed on in the right order else you can destroy the bearing...
    I would imagine it would cost no more than around £30 in labour to get both new bearings pressed in if you presented the new bearings and uprights to a garage
    <tuffty/>
    Jun 2012
    Redhill Surrey
    635
    Cheers tuffty pretty much as I thought really, the cheapest price I got was £40 a side if I supplied, but I'm more than confident in getting the hubs off and taking those down to see if its better price, see if I can do it this weekend as well as the poly bushes
    May 2012
    RETFORD, NOTTS
    1,753
    I was actually in kwikfit yesterday trying to get to the bottom of a suspect bearing (wanted to put it on there jiggly mot ramp!).
    Conclusion was no play whatsoever on any wheel, but on test driving possibly a wheel bearing starting to fail. Quote was £104 fitted including alignment. My car is in the sig, I assume yours wouldnt be much different. They wont supply or fit OEM parts though, they use there own supplier and wouldnt tell me who that was.
    The last wheel bearing i did on one of these was a royal PITA, so im going to let them do it if it develops and needs fixing before the service is due.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Wheel Bearings
    By sharpr in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2007, 16:17
  2. Wheel spacer issues
    By cclarke184 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2005, 23:23
  3. Guide Pins & Wheel bearing housing
    By neversaydie in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2004, 21:56
  4. Wheel Bearing (Spelling?) noisy
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2004, 17:34
  5. Funny noises from my S3 (Wheel bearings?)
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2003, 09:45
