Badger5EM Tuning
Results 1 to 8 of 8
    Feb 2012
    bedfordshire
    751
    Help just fitted my 6000k ds2 bulbs throws up fault on dash
    Just got to fit my new bulbs Philips and one side is working the other does not and keeps on beeping on the dash and a bulb with an x through it shows any clues anyone or is the bulb faulty ?
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    Have you tried swapping them around to see if the fault then happens on the other side ??? if it does then it's a faulty bulb
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Feb 2012
    bedfordshire
    751
    Good idea will try it
    Mar 2013
    europe
    76
    i get this rarely with my 6000k bulbs, when first fitted the passenger side bulb didnt come on, it kept showing the bulb blown warning, i just kept turning the lights on and off and it then lit up, i think the connector was not fully locked and a bit loose , it hasnt appeared since ,over a year ago
    Feb 2012
    bedfordshire
    751
    Well I changed it over and it's still not working looks to be a faulty bulb
    Mar 2013
    europe
    76
    royal mail may have dropped them if you had them posted to you, my bro has been putting shock watches in his mail , and everyone was broken when they arrived at destination only, uk post, its unusual for new bulbs to be broken .
    Feb 2012
    bedfordshire
    751
    Well I have sent it back for a replacement so hopefully get working one soon
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I got some of the 4 quid 6000 k bulbs off eBay. They keep failing to ignite, I got fed up and put my oem bulbs back in. The light is so much better on my 10 year old bulbs and they and they start first time.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  1. Fitting new ds2 bulbs.....
    By S3featesV9 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2012, 03:18
  2. Can DS2 Bulbs be fitted to my car with DS3 Bulbs fitted standard?
    By SimplyTheBest1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2011, 15:39
  3. HELP PLEASE - just fitted lowering springs ??????
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2010, 17:44
  4. just fitted neu speed induction kit help?
    By markyR in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2007, 17:20
  5. Help with fitting SYMPHONY double-din head unit
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2003, 21:29
