Monster MotorsportChris Nott
Results 1 to 32 of 32
    Feb 2013
    30
    Coil pack problems. Upgrade coil pack options ?!
    Car was firing on 3 cylinders suddenly so i changed the spark plugs in my s3 ran well for a day then the loss of power under load and misfiring started again which leads to coil packs playing up but no faults coming up on the ethos.
    I have the bolt down type coil packs
    I was thinking of replacing the set but don't know what's best as I heard you can fit the red coilpacks from the 2.0 tfsi I this correct and if so is there a certain year or is it all of them?
    Or there's an upgrade set on eBay for £90 but are not bolt down. Does this mean they won't sit properly or are they a different design that works without bolting down?
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,601
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    Aaron I just had the same thing happen to me S3 Hesitation / surging issues
    Awesome can supply a set for about £80 TFSI you may need an adapter I cant remember who but in the TFSI thread there was used of some OEM plastic modified ones.
    TFSI Coil to 1.8T adapters
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,601
    Quote Originally Posted by mattyboy199 View Post
    ....I cant remember who but in the TFSI thread there was used of some OEM plastic modified ones.
    That would be me and the link to said adaptors (and other TFSI coil pack info) would be above in post #2
    <tuffty/>
    Feb 2013
    30
    ok thanks for info. is the adapter for the connecting plug or for holding the coil in place. have you done this conversion?
    Feb 2013
    30
    <tuffty/>
    cheers for the links have you done this conversion?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,601
    Quote Originally Posted by aarondown91 View Post
    2.0 TFSI Coil Packs on a 1.8T - Page 7
    <tuffty/>
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    I know some one that has some 2.0 FSTI coil packs going spare
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    Bolt down coil packs very rarely fail.
    In fact, I don't think I have ever seen a set fail.
    Check ignition amp, as well as the wiring to the packs.
    You'll need to rewire if you want to fit TFSI packs to an ME3 car.
    I quite often say I'm going to do things.
    Then never do them.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,601
    Quote Originally Posted by 16Klappe View Post
    The OP has an S3 dude... bolt down with internal amps, not like the AGU... he can just swap over to TFSI packs and use the OE adaptors in the link I posted
    <tuffty/>
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    <tuffty/>
    I'm a d**k.
    As you were...
    Then never do them.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    They actually sit fine without adapters as well by the way...but i suppose it tidies it up..
    Nov 2005
    UK
    1,689
    tuffty from what i've read TSFI coils fitted to a bam engine is plug & play again with adapters to just smarten it right ?
    I just looked on the awesome website there is 2 sets £78 & £84, which set & whats the difference ?
    wanted for 8L S3:
    Milltek system
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Go for the one that say 06e. 07k are warned against on some yank forums. I got red ones anyhow :D
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,601
    Any engine with the push in coil packs you can just replace easily with TFSI coils... the adaptors are purely for show in this case... on earlier DBW S3 (APY) and A3 TQS with bolt downs then again they are simply swapped out for TFSI but while the TFSI (and push down 20v packs for that matter) are held securely on the plug they will wobble about at the top as there is nothing to hold them... the only choice before was to buy the expensive alloy adaptors but now of course you can buy the cheaper OE adaptors and this will secure the packs nicely...
    Early AGU engines with ignition packs can convert to later coil packs, not sure of the process as I have never done one but its popular with the AEB A4 owners stateside...
    <tuffty/>
    James TQ's Avatar
    Apr 2012
    Essex
    548
    i have the same problem iv just orderd tfsi coils and adapters from dealers but not going to need them as its the lambda sensor
    Feb 2013
    30
    Just spoke to them on the phone and was told that these don't work on tha apy bolt down coil packs because the wiring plug isn't the same?!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,601
    Not convinced... have seen APY's running these but without a coil pack in front of me I couldn't confirm for sure but I am pretty sure they are the same plug... they do differ on the AGU though
    <tuffty/>
    Feb 2013
    30
    Bit confused now:/.
    Has anyone done this to an apy that can give some advice?
    Tufty do you know anyone that could confirm this? Cheers
    So these do plug straight into the apy engine then? Just need the adapters to fill the gap and hold the top of the coil. Is that right?
    ECS Tuning Red Ignition Coil Pack Set 1.8T 150/180/210/225 - S3 (8L) - Audi - Shop By Car
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,601
    Bit confused now:/.
    Those ones are 20v coils not TFSI mate...
    <tuffty/>
    Nov 2005
    UK
    1,689
    Quote Originally Posted by James TQ View Post
    Which lambda sensor has failed on your car, pre or post cat ?
    wanted for 8L S3:
    Milltek system
    James TQ's Avatar
    Apr 2012
    Essex
    548
    vdcs says bank 1 sensor 1 im running a decat so im guessing its the one on that pipe as there is a hole for a sensor on the downpipe but its blanked off, can anyone confirm its the one on the decat pipe?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,601
    Bank 1 Sensor 1 is the precat probe
    <tuffty/>
    Feb 2013
    30
    <tuffty/>
    wrong link sorry. Will the 20valve ones fit straight onto mine then? Or will they not work due to not being bolt down ?
    These are the tfsi ones
    ECS Tuning Red Ignition Coil Pack Set 2.0TFSI - S3 (8L) - Audi - Shop By Car
    James TQ's Avatar
    Apr 2012
    Essex
    548
    is the precat probe the one on my decat pipe as i cant see any other on the system unless theres one in the manifold there is space for one on the downpipe but its beed plugged off, am i right in saying my car only have one of the lambda sensors?
    Nov 2005
    UK
    1,689
    James it depends what year & engine your car is, older engines have 1 & newer engines have 2.
    wanted for 8L S3:
    Milltek system
  28. #27
    James TQ's Avatar
    Apr 2012
    Essex
    548
    1999 a3 quattro ajq
  29. #28
    Feb 2013
    30
    how much did you pay for them with adaptors?
    was it for an apy engine?
  30. #29
    Nov 2005
    UK
    1,689
    <tuffty/>
    But which ones ?
    wanted for 8L S3:
    Milltek system
  31. #30
    James TQ's Avatar
    Apr 2012
    Essex
    548
    ajq code packs were £77 adapters £1.20 each plus vat from dealers
  32. #31
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,601
    These...
    <tuffty/>
  33. #32
    Sneekyparrot's Avatar
    Jun 2012
    Birmingham
    42
    Quote Originally Posted by Andrew@A.L.D View Post
    New or used?
    Need a set to convert my BAM Motor.
    cheers
    Paul
  1. Coil over problem?
    By supanova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2012, 15:34
  2. Light Pack Problem
    By kite in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2011, 14:33
  3. Upgraded igntion coil packs?
    By legal_ice in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2010, 22:41
  4. Vag Com in North London or Nearby...potential coil pack problem
    By Tekin in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2008, 00:32
Tags for this Thread
