AH FabricationsVolks Autos
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    S3 Hesitation / surging issues
    I recently replaced my plugs due to hesitation / surging issues & initially all was good however in higher gears 3rd + it has re-occurred. Today the EML light was flashing I haven't scanned it but I am already aware of the lambda sensor number 2 being faulty, this hasn't affected MPG & I do not believe there causes any adjustment in the fuelling made by the ECU. When I previously removed the lambda sensor it was black & easily wiped clean my intension was to cure the hesitation issue then clean up the lambda probe however i'm at a bit of a dead end. The coil pack wiring loom is all good the only thing which springs to mind is coil packs & although their 50k old they look in good condition (not cooked / tarnished).
    Anyone else had this problem ? i'm concerned it could be a turbo issue.
    Regards
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Nov 2005
    UK
    1,688
    I'm planning to do some VCDS logging today so hopefully this will highlight the issue.
    wanted for 8L S3:
    Milltek system
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    possibly a boost leak?
    Nov 2005
    UK
    1,688
    hmmm...this says coil packs to me, the 17526 & 17522 are related (lambda) not sure about the 17705...
    Gonna switch over coils 3 & 4 with 1 & 2.
    VCDS-Lite Version: Release 1.2
    Wednesday, 20 March 2013, 18:53:55.
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: Redir Fail!
    Controller: 8N0 906 018 BH
    Component: 1.8L R4/5VT 01 0001
    Coding: 10710
    Shop #: WSC 00000
    7 Faults Found:
    17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
    P1118 - 35-00 - -
    16684 - Shareware Version. To Decode all DTCs
    P0300 - 35-10 - Please Register/Activate - Intermittent
    16685 - Shareware Version. To Decode all DTCs
    P0301 - 35-10 - Please Register/Activate - Intermittent
    16688 - Cylinder 4: Misfire Detected
    P0304 - 35-10 - - - Intermittent
    17522 - Shareware Version. To Decode all DTCs
    P1114 - 35-00 - Please Register/Activate
    17705 - Shareware Version. To Decode all DTCs
    P1297 - 35-10 - Please Register/Activate - Intermittent
    16687 - Cylinder 3: Misfire Detected
    P0303 - 35-10 - - - Intermittent
    Readiness: 0010 0001
    Address 03: ABS Brakes Labels: None
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E0FBDFB296F
    No fault code found.
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E0FBDFB296F
    wanted for 8L S3:
    Milltek system
    Nov 2005
    UK
    1,688
    Coils switch last night, faults codes found below.
    16684 Random/Multiple Cylinder Misfire Detected
    16685 Cylinder 1: Misfire Detected
    Cylinder 1 has coil 3 in it, this makes sense to misfire. What I don't understand is why cylinder 2 (previously coil 4) & 3 (previously coil 1) have not misfired.
    I need help please guys !
    wanted for 8L S3:
    Milltek system
    Nov 2005
    UK
    1,688
    As suspected 4 x new TFSI coil packs cured this problem HAPPY TIMES !
    wanted for 8L S3:
    Milltek system
  1. Replies: 4
    Last Post: 11th February 2013, 14:08
  2. Clutch Hesitancy issue
    By steve123a in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2008, 15:54
  3. Surging Issue - Map itself?
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2008, 11:06
  4. Surging Issue - Map itself?
    By fran-s3 in forum Tuning
    Last Post: 28th August 2008, 12:25
  5. Revo Remap - Hesitation issues
    By creepy800 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2007, 08:55
