I recently replaced my plugs due to hesitation / surging issues & initially all was good however in higher gears 3rd + it has re-occurred. Today the EML light was flashing I haven't scanned it but I am already aware of the lambda sensor number 2 being faulty, this hasn't affected MPG & I do not believe there causes any adjustment in the fuelling made by the ECU. When I previously removed the lambda sensor it was black & easily wiped clean my intension was to cure the hesitation issue then clean up the lambda probe however i'm at a bit of a dead end. The coil pack wiring loom is all good the only thing which springs to mind is coil packs & although their 50k old they look in good condition (not ****** / tarnished).
Anyone else had this problem ? i'm concerned it could be a turbo issue.
Regards
Matt
Regards
Matt
