    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,454
    Injectors - dead time - voltage - pressure
    just trying to interpret this data:
    https://docs.google.com/file/d/0B-z7...it?usp=sharing
    supplied by USRT.
    i like to understand things you see.
    now from what i know injectors have a 12v feed. so why the data for other voltages?
    the differences in dead times seems quite big between say 12v and 14v.
    but they dont alter a great deal with differences in fuel pressure (3bar - 7bar)
    if you run at standard 3bar, with 12v feed, the dead time will be 1.12ms. rising to 1.17 if running say 2bar boost.
    just trying to understand this a whole lot more basically, i like to be a nerd. If someone has good knowledge of this sort of thing please share.
    beachbuggy's Avatar
    Surrey
    1,727
    supplied by USRT.
    The graph is used when tuning TVUB map which is the voltage compensation map. Injectors don't get a pure 12 volts all the time and this map is used to compensate for that.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,454
    do they use it to try and keep the dead time the same all the time?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    13.8v is more normal running voltage... cranking will be less of course..
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  1. 2.5TDi Injector pump timing & Needle lift sensor.
    By AlexGSi2000 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th August 2012, 13:08
  2. Oil pressure light is on & three deadly beeps!
    By S3KO4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2011, 22:20
  3. Engine dead...2.0TFSI - Result of oil pressure light coming on.
    By Adam31 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2011, 19:25
  4. Anyone got some S3/TT injectors i might be able to borrow for some time?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2010, 10:46
  5. injector on time?
    By dultanur in forum VCDS (formerly VAG-COM) forum
    Last Post: 31st October 2006, 16:36
