Injectors - dead time - voltage - pressure
superkarl
MAN OF STEEL
Liverpool/Southport. N west
just trying to interpret this data:
https://docs.google.com/file/d/0B-z7ncRSik0peld5clJIZ0pTZ3c/edit?usp=sharing
supplied by USRT.
i like to understand things you see.
now from what i know injectors have a 12v feed. so why the data for other voltages?
the differences in dead times seems quite big between say 12v and 14v.
but they dont alter a great deal with differences in fuel pressure (3bar - 7bar)
if you run at standard 3bar, with 12v feed, the dead time will be 1.12ms. rising to 1.17 if running say 2bar boost.
just trying to understand this a whole lot more basically, i like to be a nerd. If someone has good knowledge of this sort of thing please share.
supplied by USRT.
The graph is used when tuning TVUB map which is the voltage compensation map. Injectors don't get a pure 12 volts all the time and this map is used to compensate for that.
C
554
colicabcadam
C
6
818
